Enthusiast ![]() ![]() ![]() ![]() Joined Oct 31, '03 From Orlando, Florida Currently Offline Reputation: 0 (0%) ![]() |
Well guys, a few days ago my system suddenly turned off... today i decided to check the amp fuses and low and behold, 1 was blown, and the other i blew when taking it out
![]() ![]() Suggestions/ Solutions? Thanks guys... obviously you know a lot more than me |
![]() Enthusiast ![]() ![]() Joined Aug 26, '04 From Vancouver, WA Currently Offline Reputation: 0 (0%) ![]() |
Check to make sure your power wire is not grounding some where, also check your speaker wires are not shorting to the car, or to each other.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
Make sure you , he said, The power wire goes to the power in the amp, and ground to gorund. It sounds stupid, but I know I have croosed them a ton of times.. and I have been doing wireing for 4 years. Also check the ground. ALso your amp could be blown.
![]() Enthusiast ![]() ![]() Joined Sep 10, '04 From san diego Currently Offline Reputation: 0 (0%) ![]() |
1. check all fuses...even a slight touch from a fuse to the amp can blow it
2.check the power wire...even tho the amp is off power is still there.. 3. ground cannot be longer then 3 feet long and get rid of all paint on it |
thanks guys... ill check this all out very soon and if all else fails ill take it into an audio shop... i just hope the amp is not blown
![]() This post has been edited by tim86: Oct 7, 2004 - 5:17 AM |
Lo-Fi Version | Time is now: February 22nd, 2025 - 11:38 AM |
