Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) ![]() |
shakes above 80 and pulls to the right...
is that off balance or out of alignment? This post has been edited by celicarocker: Oct 6, 2004 - 9:13 PM -------------------- ![]() |
both
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
It might not be.. Mine did that, after 65 mph, It shook real bad in the steering hweel an shook the car, and pulled left. Later when I pulled off my tire , I relized I swaped the front two when i painted them, I swaped back, got a new tire and got it balanced, it fixed it, I can go 115 an not shake or nothing, and it goes stright.. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) ![]() |
wheel bearing will make it pull and shake as well, pray that this isnt the case
This post has been edited by fastgt: Oct 7, 2004 - 4:50 PM -------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
![]() Enthusiast ![]() ![]() Joined Jun 29, '03 From canoga park , ca Currently Offline Reputation: 0 (0%) ![]() |
has this happened the whole life of the car?? its your alignment and most likely the speed rating of your tires. my car used to shake like crazy, but then i found out the tires were only good for 110 mph. i got some ones that are good for 140 and no more shaking. as for your steering wheel pulling is it like a real sharp pull or just gradual?? hope that helps.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
first have all your tires balance and see if the tread is all close (meaning taking a tread depth reading across the tire to see if you have uneven wear) while they have it up in the air have them check the bearings by wiggling the tire. If that does not solve it move on to an alignment.
![]() -------------------- yea your 3sgte is cool but ill stick to my 7agte
the tires are pretty new, so the tread shouldnt be too much of an issue. and no this hasnt happened the whole life of the car, ive only noticed it say about a month. im going to have the balance checked on the tires on wednesday.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
Prior to spending any money on rebalancing, I would closely inspect all the tires for defects. I have had tire bulges that cause similar shaking. If so, its silly to spend money getting the other tires rebalanced.
im not spending any money... my stepfather has a garage at his house with all the equipment so as long as nothing needs to be bought, i can get it all done for free... -------------------- ![]() |
Lo-Fi Version | Time is now: February 24th, 2025 - 5:29 AM |
