2 Pages V  < 1 2
> big brake kit
post Oct 21, 2004 - 1:26 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (Kwanza26 @ Oct 8, 2004 - 1:10 AM)
QUOTE (shadycrew31 @ Oct 7, 2004 - 6:52 AM)
well why dont you go buy a brembo set of brakes for a gt. and try and fit them on your st. opps wont work. tried it and so did others.
Cause you need the hub genius... rolleyes.gif can't just "bolt" everything up.
I love reading your posts when you get aggravated.
Obviously the guy doesn't understand the whole 'suspension' thing. Hopefully he can learn from this thread.
ATTENTION: Has anyone confirmed that the rear 'big brake' for a 7th gen can fit on a 6th. Last time this topic came up, most were unsure if that rears of the 7th and 6th share the same design. Any info is nice. smile.gif
-Ti
post Oct 21, 2004 - 1:43 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (turboinduction @ Oct 21, 2004 - 6:26 PM)
-Ti
The rears I have confirmed do not fit. The 7th gen Celicas use wishbone rear as opposed to the 6th gens using macphearsons...
As for the steel braided lines... most of them are designed for competition... so reliability should not be an issue with them. They are probably more reliable than stock lines...
post Oct 21, 2004 - 2:33 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
thx for the info - thats all I needed.
-Ti
post Oct 23, 2004 - 4:31 PM
jgreening
Joined Jan 17, '04
From Illinois
Most big brake kits are front only. Big brakes in the front and the GT brakes in the rear is all that 99% of us would ever need.
post Oct 23, 2004 - 4:38 PM
shid
Joined Jan 8, '04
From LA
I was shooting the breeze with some WRX guys and they said that with a brembo kit you need new special brake fluid and a few other things?
post Oct 24, 2004 - 12:00 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
like, do you need to be able to replace to where they are not intended for winter or anything at all
post Oct 25, 2004 - 10:53 AM
ConeTrouble
Joined Nov 25, '03
From Mizzeri
QUOTE (recneps @ Oct 21, 2004 - 3:43 AM)
when i had my gt i could hit the brakes really hard about 3 times (not locking them up) just to heat them up. and they would get so hot in just those 3 hard brakings that i couldnt even lock them up at all after that no matter how hard i tried.
If this was happening you have a problem in the brake system somewhere.
My first suggestion to you would be to bleed your brakes. Most likely what has happened is that you have some water in your lines. This is something that happens over time, as most brake fluid is hygroscopic (absorbs water) and absorbs water out of the atmosphere. When this happens, then end result is that you are reducing the boiling point of your brake fluid. Then when you hit the brakes hard a couple times, the brake fluid will boil, generating air in the brake line, which, unlike liquid, will compress under pressure.
QUOTE (Consynx @ Oct 24, 2004 - 5:00 AM)
can the lines rust
No, the lines cannot rust. They are braided stainless steel brake lines; however, they are not invunerable. You will have to take care of them just like you would if you have regular lines (i.e. bleed the brakes every year or so).
My opinion about this big brake thing is this - unless you are doing track days at a racetrack, or maybe performance driving schools at a track, you DO NOT need a big brake kit. If you just want one because they look cool and fill up the gap of your bling-bling wheels better, fine, good for you, but make no mistake about it, they are not *needed*. The stock brakes work VERY well when taken care of. I autocross my Celica a LOT, and have never felt the need for more braking. A typical autocross will put much more stress on the braking system than you would ever see on the street, and I just don't see the need for a big brake kit. I will say that the kits do look good, though, and certainly don't begrudge anyone for throwing one on. I am also not saying that it wouldn't help braking, as it would, I am just saying that it isn't 'needed'. There is a difference.
post Oct 25, 2004 - 12:05 PM
jgreening
Joined Jan 17, '04
From Illinois
I agree with this too. My post was just to point out that big brakes in the back are even more overkill.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 18th, 2025 - 4:25 PM
