> Sub Woofer Help, Sub cutting in and out!
post Mar 10, 2003 - 10:16 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
Ok well I have a kicker 15 running off a 600 watt amp. Well the sub keeps cuttin in and out as I go down the road. What could be the problem? Someone told me instead of bridging it....to run like one from each of the two channels to the speaker. Should I do that?
99 Toyota Tacoma
post Mar 10, 2003 - 11:08 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
sounds like ur ground wire to me.... check that and all other connections
post Mar 11, 2003 - 1:41 AM
I'd guess that it's your ground as well. Let us know if that isn't the problem.
post Mar 11, 2003 - 1:53 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Is this a new problem or has it happened all along?
It sounds like the amp maybe overheating and going into thermal protection.
post Mar 11, 2003 - 2:33 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
OK i put a bigger ground wire and everything but the damn think still keeps cuttin out...........why?
99 Toyota Tacoma
post Mar 11, 2003 - 3:01 PM
AudioFreak
Joined Dec 19, '02
what kind of amp is it?
post Mar 11, 2003 - 4:03 PM
JWalk1818
Joined Aug 30, '02
From North Carolina
AMP- ****ty URABAN WORKS AMP
SPeaker - Kicker Impulse 15
4 ohm
dual voice coil
99 Toyota Tacoma
post Mar 11, 2003 - 6:05 PM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Check all your wiring. If it only happens while your driving then it sounds like wires are loosing contact. Also it might be a problem with your power supply gettin short. So your amp might be taking more than your battery and alt. can take.
post Mar 11, 2003 - 8:15 PM
AudioFreak
Joined Dec 19, '02
From what little info I found about Urban Works the amps are not bridgeable. If you are bridging the 2 voicecoils to a 2ohm load that is probably the problem. Try one voicecoil to each channel and see if the problem stops.
post Mar 13, 2003 - 9:29 AM
JWalk1818
Joined Aug 30, '02
From North Carolina
Well I found the problem!
1. The remote was hooked to the cig lighter casue my other remote was hooked to my power antenna I dont have anymore!
2. The cig lighter had to much on it and it wasent putting out enough power to keep the amp on!
FIXED
1. Took the remote loose from the antenna wire
2. Ran it back to the rear and hooked it up to the amp and now I got some MAJOR BASSSSSSSSSSSS! LOL not really but, enough for me
THANKS FOR EVERYONES HELP
99 Toyota Tacoma
post Mar 13, 2003 - 4:48 PM
AudioFreak
Joined Dec 19, '02
glad you found the problem
Lo-Fi Version Time is now: December 2nd, 2024 - 11:41 PM
