Enthusiast Joined Oct 8, '04 Currently Offline Reputation: 0 (0%) ![]() |
hi. ive been looking at the board for a while but never posted anything till now, here goes.
sometimes when i go to start my car (stock 94 celica st), instead of turning over it just like clicks. itll do it a few times then start just fine. sometimes it will start to turn over then stop, as if the battery is about dead. however, i know this isnt the case because i replaced it first (it tested "weak" on my tester so i thought just maybe...but no luck). the terminals arent dirty/corroded. it acts as though there is a loose connection or as i said, the battery is dieing. also, it seems to do it less when its warmer, in the morning when its still a little chilly outside its way worse. it never does it just after its been running. any help would be greatly appreciated. thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
go get your starter and alternator checked
-------------------- yea your 3sgte is cool but ill stick to my 7agte
![]() Enthusiast ![]() Joined Jul 30, '04 From colorado Currently Offline Reputation: 1 (100%) ![]() |
its the starter contacts. easy to replace! remove the starter and the solonoid cover replace one contact and then the other.then buff the plunger with a wire brush and put it back together.
yup, starter..had the same problem...have lifetime warranty for the one thats in there, so i just pulled it, and returned it for a new one..
![]() -------------------- Former Team 5SFTE pro member ;)
Enthusiast ![]() Joined Sep 3, '04 From Avondale, AZ Currently Offline Reputation: 0 (0%) ![]() |
happens all the time, a new starter will fix it, and if not maybe the alternator needs to be replaced
u don't need a new alternator and u don't need to spend the money on a new starter, the contacts only cost about two bucks each. iv'e done this to hundreds of toyota's including my celica.
thanks, do i have to get the contacts from like a toyota dealer? or is there a website i can order from?
i could really use a good oem celica parts website because i also need the washer fluid reservoir and possibly pump (i noticed when i tried to put in washer fluid that it just runs right out onto the ground lol) the pipe extends into nothingness, it was missing when i got the car a few months ago and ive been putting it off, but with winter coming i need to fix it for ice melting purposes. thanks again |
u could them from a toyota dealer but you will pay a little more or you could go to any shop that rebuilds toyota starters and they could prob get u the contacts
Enthusiast ![]() Joined Sep 14, '04 From miami Currently Offline Reputation: 0 (0%) ![]() |
you well have to change the starter sooner or later but if at one point it still clicks just get a stick and hit the starter.....not to hard just be nice
This post has been edited by 62-1celi: Oct 10, 2004 - 11:24 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
If that doesnt fix it, you could have some faulty wiring that is causing same resistance and draining your battery.
i have electrical testers. any ideas on how to test that? like voltage i SHOULD have at the starter when i crank it? thatd be 12 right? suppose i could check the alternator by checking the voltage from the battery while its running? should be about 13.5v if charging correctly right? oh and im not saying that voltage = resistance i know theyre not the same
![]() This post has been edited by slowerthanu: Oct 11, 2004 - 11:14 AM |
u should have 12 volts at the starter allways and 12 volts at the s terminal on the starter when u crank it. there be very little if any resistance from ur battery cables or the starter contacts. and should be 14 to 14.5 volts when charging
Lo-Fi Version | Time is now: February 17th, 2025 - 10:33 AM |
