> the 5sfe can handle more boost than, the 8 psi people say it blows up on.
post Oct 9, 2004 - 2:37 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
when i first installed the turbo i ran 5psi. then after awhile i was bored with it, turned it up to 10psi, NOW the boost contoller loosed up on the highway and i was back to stock. so i got home turned it back up and put a lock nut on. i just set the boost by eye. i get in the car and drive 5psi...8psi...10psi.. 13psi bab! i was like ehhhhh should i keep it? so i made a few runs. holy crap theres a big difference from 10psi to 13psi. in first ill launch so i dont sit and burn tire then shift hard into secound and it will spin for a few seconds then one u get traction around 3k then at 4.5k u loose it all again the tires just break free when 13psi is coursing through its veins lol. 3rd gear will just chirps the tires when the boost hits the pick up in crazy. donate so i can dyno lol. college is eating me.
post Oct 9, 2004 - 2:47 PM
shid
Joined Jan 8, '04
From LA
Good to hear itchy; I was pretty sure it could take up to 10 psi; 12 with a proper fuel system. I think most of us are just being cautious tho
post Oct 9, 2004 - 3:18 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
post Oct 9, 2004 - 10:25 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
damn 13 psi. so the stock engine can handle this then that awesome to hear. does the stock ecu do all of the reatrding in timing since you have an OBDII system?
This post has been edited by rjbibeau: Oct 9, 2004 - 10:26 PM
post Oct 9, 2004 - 11:54 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
no ive got the msd boost timing master.
post Oct 10, 2004 - 4:19 PM
FallenHero
Joined Dec 26, '02
From Alabama
ask DG performance about how high boost can be before the engine goes. As he said, and I quote, "I turned the boost up and it was Great till my engine blew." Turn the boost down, or walk home.
I hate to be the bad guy, but that's just what he said. I think he was boosting 14lbs.
post Oct 10, 2004 - 5:50 PM
OrbitalGT95
Joined May 3, '04
From pittsburgh
Dave blew his engine???..wtf..i just saw him last week and it was fine..and he was only boosting around 5psi
Now SR powered
post Oct 10, 2004 - 6:20 PM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
That was when he had his 5sfte
This post has been edited by vangSTa_celica: Oct 10, 2004 - 6:23 PM
A Jaws4God Creation...
post Oct 10, 2004 - 6:30 PM
celicarocker
Joined Sep 25, '03
From cranston RI
QUOTE (x_itchy_b_x @ Oct 10, 2004 - 12:54 AM)
post Oct 10, 2004 - 8:36 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
oh yeah hahahah. ill wait till it blows lol get a new 5sfe for $500 lol.
post Oct 10, 2004 - 8:50 PM
FallenHero
Joined Dec 26, '02
From Alabama
$500! Hell yea dude. No problem there.
post Oct 10, 2004 - 9:22 PM
1bwilson
Joined Aug 30, '02
From Maryland
Dave never had a BTM. He was running the 5sfte the old school way with the timming retarded manualy.
Member of Team 5sfTe
post Oct 10, 2004 - 11:28 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
IS there really a risk of blowing up your block? b/c that seems impossible. More likely a piston ring or rod. So if you get super nice pistons, etc, I don't see why the 5sfe can handle larger amounts of boost.
post Oct 10, 2004 - 11:32 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
yeah ive seen pictures of peoples blocks with golfball size holes in them. but the 5 block is iron so i doubt you whouls put a hole in it. plus the crank is forged so. yeah some forged pistons arp head bolts and some nice eagle rods and you good to throw tons of boost in the 5s.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 11, 2004 - 12:04 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
post Oct 11, 2004 - 12:07 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE (recneps @ Oct 10, 2004 - 9:32 PM)
agreed. When most people 'blow' their engine they are normally referingt to killing a piston, blowing out a head gasket, or 'frying' a piston ring..wink.gif
post Oct 11, 2004 - 2:24 AM
CheesyLobster
Joined Jul 19, '04
QUOTE (recneps @ Oct 11, 2004 - 5:04 AM)
Heheheh, wow.
post Oct 11, 2004 - 7:04 AM
be carefull and dont go boost crazy. keep it at 10psi like u had all this time.
i could probably turn up 3s up to 25psi and have a nice run with it.... but id have a damaged engine if i kept something like that set for daily use.
post Oct 11, 2004 - 9:58 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE (recneps @ Oct 11, 2004 - 1:04 AM)
ewwww.... yeah this 13psi is only gunna be used for track or racing. ill put it back to 10psi for now but im gunna miss it lol. gives me more insentive to get rods/pistons/and cams. thats all i want then im done spending money on the car.
post Oct 11, 2004 - 10:37 AM
dabbill
Joined Aug 26, '04
From Vancouver, WA
I put 2 holes bigger then that in my 7a block :/ Throwing a rod at 5k RPM does wonders to the block heh frown.gif
Lo-Fi Version Time is now: November 27th, 2024 - 5:03 PM
