![]() Enthusiast ![]() Joined Jul 11, '09 From UK Currently Offline Reputation: 2 (100%) ![]() |
Gen 6 jdm folding mirrorz
pre96 used a control relay to operate the mirrors Facelift just used the mirror switch to control the mirrors you can tell the difference as the pre 96 has 1 pink wire that sends the signal to the mirror control relay. |
![]() Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) ![]() |
nervermind
![]() This post has been edited by BloodyStupidDavey: Dec 30, 2009 - 6:04 AM -------------------- Davey
Items for sale |
this thread needs to be cleaned. too much scattered info.
I picked a set recently...swapped the motors into my USDM mirror housings, re-wired the mirror switch to match the JDM pins, ran 2 wires to each mirror, and BAM, folding mirrors with the touch of a switch.
crappy vid, I'll take more another day. ![]() yay ! -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
great work
![]() Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) ![]() |
For those of you who wants 5th gen mirrors on his/hers 6th gen:
schematic of 5th gen power folding mirrors: ![]() -------------------- JDM ST205
to add to the mess of info, i have one of the 94-95 mirror control boxes for sale:
http://www.6gc.net/forums/index.php?showtopic=73373 -------------------- Former Team 5SFTE pro member ;)
Enthusiast Joined Apr 21, '09 From Australia Currently Offline Reputation: 0 (0%) ![]() |
For those of you who wants 5th gen mirrors on his/hers 6th gen: schematic of 5th gen power folding mirrors: ![]() You beauty! ! I got the last piece of the puzzel I finaly going to wire my mirrors ![]() -------------------- 91 Carlos Sainz Edition # 21 out of 150
Enthusiast Joined Apr 5, '10 From Canada Currently Offline Reputation: 0 (0%) ![]() |
do you know how to fold in the mirrors ... well electrically that is
like for example if i ground the (making up wires here) purple and green wire for a second they fold in...if i do it again they fold out i want to hook my folding mirrors up to my alarm aux output (should be easy enough?) |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
the retract button on the control switch uses a positive signal (pink wire) to signal the mirror control box to open or close the mirrors. so if the aux on your alarm outputs a positive signal, then just splice it with the pink wire on the control switch.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '07 From Portland, Oregon Currently Offline Reputation: 67 (96%) ![]() |
This thread couldn't be brought back from the dead in a more timely way for me
the retract button on the control switch uses a positive signal (pink wire) to signal the mirror control box to open or close the mirrors. so if the aux on your alarm outputs a positive signal, then just splice it with the pink wire on the control switch. if it's a 94-95, no pink wire on the 96+ correct ? neither of mine have a pink wire... This post has been edited by Batman722: Jul 13, 2010 - 9:56 PM -------------------- |
right. there is only the one pink wire for retracting the mirrors for 94-95, but it's more complicated on 96+ because there are 2 retract wires (red with yellow and blue with white) on the control switch.
This post has been edited by azian_advanced: Jul 14, 2010 - 12:25 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
gotta love the pick wire... thats what i have, with a jdm relay
Enthusiast Joined May 29, '09 From Chile Currently Offline Reputation: 0 (0%) ![]() |
Sorry for bring up an old thread I just got my 6gen JDM Power folding mirrors. I'm pulling my hair just looking at it. I got the 2 mirrors and the controller. Can you guys help me out? For the controller On the top row 2 pins - space - 2 pins on the bottom row 6 pins ![]() Hi Anyone have the pinout of this switch, because I do not have the harness female. And someone has this relay ![]() ![]() 87989-17020 (4d39) Came with my JDM power folding mirror, the problem is that the colors wires is completely different from any other relay in the same part number. e.g. ![]() He detailed top 1 pink with black line 2 light green 3 space 4 white with black line 5 blue with black line 6 brown with yellow line 7 brown with red line Down 8 brown black line 9 brown 10 red clip 11 light green with black line 12 pink Someone can help me. Thanks This post has been edited by alex_xp: Jul 25, 2010 - 7:35 PM |
from page 4
The connections on the JDM control. ![]() ![]() 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster 5 - chassis 6 - power +12v 7 - right horizontal adjuster 8 - right vertical adjuster 9 - common feed to adjusters 10 - left horizontal adjuster and save yourself the trouble and get the 6th gen celica relay with wire harness. ![]() 87989-20060 -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
wow I've never really used my folding mirrors. I guess I've taken it for granted
from page 4 The connections on the JDM control. ![]() ![]() 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster 5 - chassis 6 - power +12v 7 - right horizontal adjuster 8 - right vertical adjuster 9 - common feed to adjusters 10 - left horizontal adjuster and save yourself the trouble and get the 6th gen celica relay with wire harness. ![]() 87989-20060 Azian thanks for your response. for the switch, they are not physically equal I have the 2 That of the left side is the switch of my post (the male harness is very similar to the USDM stock), and that of the right is that of your post ![]() ![]() I did a few tests of conductivity and the pines of chassis, power +12v, common feed to adjusters, they are located in pines different. In addition the button of the folding they work in different form, in the switch of the left side it is a push-button, in the switch of the right it is an on/off, for this way calling it ![]() I wait to continue testing and to do algun useful contribution to this forum. |
Enthusiast ![]() ![]() Joined Jul 15, '08 From Norway Currently Offline Reputation: 5 (100%) ![]() |
Some people say that we dont need the relay box? Got these mirrors off from a 94 JDM, and I'll got the white relay box with me. Tried to make it work without, but I cant see a way without using the relay box. When you press the fold button, it sends a activation signal, and thats not strong enough to fold the mirrors? And IF you wire it like that, you need to keep the button down until they are completely folded? And what about unfolding them?
each 94-95 mirror uses 4 wires, 2 to open and 2 to close. so the problem is not that the retract button cannot provide enough power to fold the mirrors, but there is no simple way to have that one 'retract button' wire alternate between controlling 2 wires to open then switch to the other 2 wires to close. IF you somehow find a way to wire it like that, YES you will have to hold the retract button down until it closes or opens all the way.
Lo-Fi Version | Time is now: April 24th, 2025 - 10:55 AM |
