jdm SIDEMIRROR wiring INFO, attention NEVERSTOP, CTCAT2049 |
Nov 3, 2004 - 7:54 PM |
Enthusiast Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
well since you have EVERYTHING you should be the one to figure this out for us LOL there should only be like 3 or 4 wires you will have to hook up
yea tried that and got every function to work but not at the same time or nething like that... its suck a bish to figure this out -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Nov 3, 2004 - 10:47 PM |
if he has everything shouldn't it be a straight wire up?
control switch to relay box relay box to mirror? oh and so we clarafi things......control switch is the one were you push the buttons relay is the stupid black box that TI has and the mirrors are the things on the outside of your car |
Nov 3, 2004 - 11:06 PM |
The mirrors are on the outside ? opps I screwed up.
NEVER, you might want to try using a relay or 2. Have you wired relays before ? If you need to reverse a polarity use these diagrams here (relay diagrams) also, you said you can make the mirrors move (fold) with a battery hardwired right ? What wires and what polarity ? -------------------- |
Nov 3, 2004 - 11:15 PM |
the two wires on the out side of either side (2 farthest left or right wires) polarity doesn't matter one way will move out and one way moves in
Nov 3, 2004 - 11:20 PM |
yea I just used a little 9vlt battery think some of my prob is I had 3 shorts in my circut board.. I did one of em but never noticed the other 2 cuz they where hidden under some whitish goey ****. I soddered in some copperwire to fix everything and hotglued overem so hopefully that helps.
not quite but almost.. he will still have to splice into the USDM harness to make it all work but that should only be power and ground/chassis ***BTW THERE IS A RELAY BOX ON EBAY - DON'T BID ON IT ITS MINE!!!!!!!*** its just for toyota.. the guy didnt know what vehicle it was for but still its mine -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Nov 3, 2004 - 11:23 PM |
that link might of well just said,"AHTEJAHTAWJTKJAKTHJAHTJA THAJHTKA A HATJHE ATHATHKAKJKDCNEKC NIOMEAO;NGAN AJKLSDJFLJLA" cus thats about as much since as it made to me -------------------- 99 project version 3.0.. hello SEMA 2010 =) |
Nov 3, 2004 - 11:46 PM |
I'm sorry to hear that anyway, my guess with this whole mess is - the control unit (JDM switch that goes in the door) probaly gets wired in with the up righ left down similar to US/UK/JDM (whatever the wire colors are, they are all there and will work). The wires that are for the folding go to a relay (or 2) and then to BOTH of the mirror motors (safer that way). The UK write up just bypasses the relay(s) and goes strait to each mirror motors individually (not as safe).
I will have my mirrors and switch in 6 days and on Wednesday I will be installing them. I will probaly get buy two $3 relays from radioshack to replace the toyota one because that is all it is. NEVER, learn about relays !!!!!!!!!!! you are buying one. You are going to need to know how to install it properly. I wish you guys lived close to me, I would be able to get these done. -------------------- |
Nov 4, 2004 - 12:30 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Batman, you wire the harnesses and they will come.
Get it working and name your price. -------------------- Member of Team 5sfTe
Nov 4, 2004 - 8:50 AM |
Enthusiast Joined Nov 4, '04 From UK Currently Offline Reputation: 0 (0%) |
Hey guys, the panic's over, the doctor has arrived
My name's Graham, I'm from merry olde England, I've got a '98 Celica GT, and I've fitted JDM electric folding mirrors and made them work So any questions you've got, ask away. Firstly, any of you that have got a control relay, throw it away. You don't need it! Next, for anyone who hasn't already got it, here's the circuit diagram for the existing mirrors on the USDM cars http://www.yellowsun.plus.com/how2/photos/cirdiag2.gif This post has been edited by SilverGT: Nov 4, 2004 - 10:04 AM |
Nov 4, 2004 - 10:36 AM |
That's what I'm talking about !!!!!!!!!!!!!!!!!!!
Nov 4, 2004 - 10:42 AM |
How the JDM mirrors work.
There are just 2 wires for the retractor motor, blue and green. If you apply power to one wire and ground the other, the motor runs one way. If you reverse the polarity it runs the other way. The motor has internal limit switches to switch it off when it reaches the end of it's travel, so the power can be left on all the time. The connections on the JDM control. 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster 5 - chassis 6 - power +12v 7 - right horizontal adjuster 8 - right vertical adjuster 9 - common feed to adjusters 10 - left horizontal adjuster As for relays, I take your point about using them to save the switch, but in this case the motor current is tiny and I wouldn't have thought it necessary. The corresponding USDM loom colors 1 - retractor motor 2 - retractor motor 3 - spare 4 - left vertical adjuster - BR/Y 5 - chassis - W/BK 6 - power +12v - GY 7 - right horizontal adjuster - LG 8 - right vertical adjuster - LG/BK 9 - common feed to adjusters - LG/R 10 - left horizontal adjuster - BR/W GY = Grey W = White BK = Black BL = Blue BR = Brown R = Red Y = Yellow GR = Green LG = Light Green This post has been edited by SilverGT: Nov 6, 2004 - 6:22 AM |
Nov 4, 2004 - 2:05 PM |
Enthusiast Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
thanks SilverGt, i'm the one who emailed you
Are you sure that is the controls for ALL JDM control units? I only ask because I board looks different -Ti |
Nov 4, 2004 - 2:09 PM |
And one more.... yeah
Now assuming the break down you gave us above is correct for all models, how do we go about working with it. Does the stock USDM harness plug right in and all we have to do is splice in the two extra wires for retract and expand? Thanks -Ti |
Nov 4, 2004 - 3:04 PM |
I've got no idea. The truth is I've only seen the one I've got, and I never got to see the car it came from. |
Nov 4, 2004 - 3:11 PM |
The JDM plugs and sockets are different to the ones in my car, so no, it didn't just plug in. You could cut the plugs off and just join up the new wires, but I choose to splice in behind the plugs so that all the original stuff is still there. But in essence, all you have to do is connect up the existing wiring to the new control as the old one was, and add the 2 wires for the retractors. |
Nov 4, 2004 - 10:09 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Sweet, I recieved my mirrors today. SilverGT thanks for the great info ! Could you take pictures of your wires and how they are spliced.
also, how did you run the retract wires up to the mirror ? Thanks, DEF -------------------- I will return one day. |
Nov 4, 2004 - 10:20 PM |
yea your pins are different then mine for the control...
i have 3 on top and 5 on bottom 1 in the top left two on the top right and five straight across the bottom |
Nov 4, 2004 - 10:21 PM |
oh and i don't understand a single thing on that last think posted
Nov 4, 2004 - 10:35 PM |
I've got a pink wire - anyone know what that does. Its part of the cut off harness thats in my JDM control unit......
-Ti |
Nov 4, 2004 - 10:42 PM |
this is how my wires are
3 top pins top left pin : brown wire w/ silver spots top middle pin but on the right side: blue wire w/ red stripe top Right pin: gray wire w/silver spots bottom pins from left to right: pink w/black strip pink w/white strip puke green w/black strip puke green w/red strip red w/ silver spots edit= all wires have silver spots lol This post has been edited by playr158: Nov 4, 2004 - 10:42 PM |
Lo-Fi Version | Time is now: November 27th, 2024 - 6:30 PM |
