16 Pages V   1 2 3 > »
> jdm SIDEMIRROR wiring INFO, attention NEVERSTOP, CTCAT2049
post Oct 10, 2004 - 12:20 PM
OK after about 10 min....3 15amp fuses and some playing
if you hook the RED wire at the MIRROR to a power source
then a GROUND to the BLACK wire at the MIRROR you get it to move DOWN
then a GROUND to the BROWN wire at the MIRROR you it to move RIGHT
thats as much info as i have now....
BUT that is not goin through the "relay/control switch" that is just wires to wires
post Oct 10, 2004 - 3:21 PM
on the mirror the two outside wires on eachside *all the wires EXCEPT the brown, red, and black* control the retractable motor......you can put positive on the left and ground on the right and it goes one way...switch the wires and it goes the other way....same for both sides
post Oct 10, 2004 - 4:23 PM
post Oct 11, 2004 - 11:27 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
thats awesome.. I was gonna mess around with mine today but ended up not having time.. did you get urs to work fully??>?
post Oct 12, 2004 - 1:53 AM
Don't you still need the relay box so that the box can sense motor resistance and stop applying power to the motors?
post Oct 12, 2004 - 9:09 AM
neverstop-no i havn't gotten them to work cause i havn't gotten it compatable with the relay box that you control it with
Coomer-yes you still need it i'm still trying to figure out how to do it
post Oct 12, 2004 - 11:33 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
wait.... relay box?? is there something I'm missing?
I have the mirrors and the little controller thing you pop into your door panel to replace the stock one... is there something else?
post Oct 12, 2004 - 2:30 PM
post Oct 12, 2004 - 9:24 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
edit: hurry up! LOL j/k but I do want mine to work also and wanna see if you figure it out.
also want suggestions on how to make it work with the ignition.. like you turn on the car and they fold out and turn off the car and they fold in
This post has been edited by NEVERSTOP: Oct 12, 2004 - 9:25 PM
post Oct 12, 2004 - 10:35 PM
yea well i'm on GMU's dive team, and that is a ton of time i have to do that.....and i'm getting really pissed about it so i'm trying to quite maybe so i'll have more time.....and my pop's is goin to help me work on them when i have free time so i'll let you know NEVER when i get the time.........and when i said the two wires on each end of the plug that is onthee actual mirror do the retracting i believe one side's wires are the button and the other sides mirrors are the ignition you can try and find out which side is which
post Nov 1, 2004 - 12:51 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
ne updates on this???
I messed around with mine a little today.. I got most of the functions to work on the drivers side mirror.. I just cant seem to make it go down frown.gif
The mirrors moving is AWESOME!!!!!!!!! I cant wait to have it all hooked up.
Playr... some of my pins are different than yours.. Im hopefully gonna try and work on it some more tomorrow and I'll make a cool little diagram like yours to compare.
edit: is it possible that toyota made different versions of the folding mirrors?? the back of my relay box has a total of 10 pins in it... 6 across the top row and then two section on the lower row of two each
This post has been edited by NEVERSTOP: Nov 1, 2004 - 12:58 AM
post Nov 1, 2004 - 9:51 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
Heres what I got
Do you guys have this piece?
-Ti
post Nov 1, 2004 - 10:11 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (NEVERSTOP @ Oct 31, 2004 - 11:51 PM)
My relay has even more:
Relay
6 across the top left to right:
Blue/White
Blue/Red
Space
Blue/Yellow (this is the only one i cant figure out)
Pink
Green/Yellow
Red/Yellow
5 across the bottom:
Blue
Brown
White/Black
Space (Clip)
Yellow
Green
The Actual control unit, the piece on the door that you push that makes the mirrors move
Contorl Unit
4 across the top row:
White/Black
Teal/Red
Space
Space
Teal
Gray
4 across the bottom row:
Brown/Yellow
Brown/White
Space (clip)
Teal/Black
Pink
Left mirror - drivers mirror USDM/Passenger Mirror JDM
Left Mirror
5 across the top row:
Green/Yellow
Space
Teal/Black
Teal/Red
Teal
Blue/Red
2 across bottom row:
Red/Yellow
Space (clip)
Blue/White
Right mirror - passenger's side USDM/Driver's Side JDM
Right mirror
Yellow
Space
Brown/Yellow
Teal/Red
Brown/White
Brown
2 across the bottom row:
Green
Space (clip)
Blue
Now each of these wires can be matched to another except Blue/Yellow in the relay itself. This could be ground though. Let me know guys.
-Ti
This post has been edited by turboinduction: Nov 1, 2004 - 12:19 PM
post Nov 1, 2004 - 10:30 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
blue/yellow, sounds like a remote control wire...that would be amazing...
j/k
so what all of you are sying is that each set of mirrors is different...great
post Nov 1, 2004 - 11:58 AM
ok we didn't get that relay box.....we only have the control unit that goes in the door......
and the wires are the same for all of them
but why do we need the USDM mirrors----you got that wrong those are only 3 wire
you posted the JDM mirror wires
post Nov 1, 2004 - 12:03 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (playr158 @ Nov 1, 2004 - 10:58 AM)
didn't understand you here?
Neverstop is missing the relay too?, and I posted all of the JDM stuff.... No USDM in there.
Also found this, for a 5th, but it might help
http://www.radcastro.com/Projects/Project+ST2GT4/580.aspx
-Ti
EDIT: ohhhh, i see what you meant.... No, those ARE JDM specs i gave.... I said USDM driver because I didn't wanna confuse people if I said Driver's mirror (meaning left) and they thought right because of the JDM.
This post has been edited by turboinduction: Nov 1, 2004 - 4:41 PM
post Nov 1, 2004 - 1:29 PM
yea i don't have that cpu relay box i wanna find a way to get around it since its not really easy to find
post Nov 1, 2004 - 5:42 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
My set of mirrors are on the way, with control & relay. I'll try to add what I can when I get them. I got the 6th gens as well. I also want to find out how to hook them up so they open when starting the car, and close when you shut off the car.
Guess I'm a 6 g c p i m p haha
Later,
DEF
I will return one day.
post Nov 1, 2004 - 5:51 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
QUOTE (defgeph @ Nov 1, 2004 - 4:42 PM)
Later,
DEF
wink.gif , now you can add that little power folding mirror slogan into your sig like Never and I. YOU TO PLAYR!
-Ti
post Nov 2, 2004 - 12:12 AM
I just got the set that was on ebay. I am kinda excited but I think I am having second thoughts.
I might want to sell these instead of installing them. No extra charge, just what I paid. Any interest, PM me.
Lo-Fi Version Time is now: April 24th, 2025 - 9:38 AM
