Enthusiast ![]() ![]() Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) ![]() |
in the mornings when i try to fire up my st204 the engine dies after a sencond after it starts running could it be the fuel pump or is it something else?
Does it start up at all?
Could be your cold start injector. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
Have you tried revving as you start her up?
What does your tach do? Does it go to normal, then shoot down to 200, then die? If so, you've got a sticky idle speed sensor. |
it starts up but after a second it dies and i've tried revving it and that is how i can drive it but right when i let off the clutch the engine dies
How high do u rev it? i had to rev mine to 4-5k when I had this problem; then it would idle normally.
Enthusiast ![]() ![]() Joined May 19, '03 From NJ Currently Offline Reputation: 0 (0%) ![]() |
I have the same problem when its cold so I rev it past 3k and then its fine. Went to AutoZone for a free check up and 4 codes where detected. The guy said that one code leads to enother one so if I fix the main problem the rest would disappear. I think the main one was absolute manifold preassure or smth. Still didnt fix that couse I don't know how.
Which means you have a leaky gasket most likely.
Lo-Fi Version | Time is now: February 22nd, 2025 - 12:07 PM |
