> The List, What happened to the List?
post Oct 13, 2004 - 12:59 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
there use to be a list of all parts used for the 3S Swap, where did it go?
there in reality should be about 3 lists complete, then several unknown ones
the 2nd gen 3S w/ 5S tranny should be a known
the 2nd gen MR2 2S w/ 5S Tranny should be known
and either of those w/ the e153 tranny should be known
just wanted to further my knowledge what what if kept at the flywheel.
3S pressure plate, 5S clutch?...yea
post Oct 14, 2004 - 8:54 AM
If you use a 3s and S54 tranny your going to use the 3s flywheel, 3s PP and 5s disc.
post Oct 14, 2004 - 12:02 PM
Consynx
Joined Dec 25, '02
There's 1 example
would that be same for all gens?
oh yea, what's this crap floating around about changing axles, i never got that far into Qatar's walkthrough before it hit an error, is there really one necessary?
post Oct 14, 2004 - 12:31 PM
Changing axles is only necessary for an E-153 (MR2) transmission, whereas you need Alltrac outter axles and MR2 inner axles.
Im not sure about the generations on the clutch, the ST165 might be smaller but I'm just guessing, dont buy a kit only buy what you need.
post Oct 14, 2004 - 12:32 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
if you use the mr2 tranny with lsd some "adjustments" have to be made and your gonna need lsd axles.
and if your doing a 3s swap in a st your gonna need either gt or mr2 axles.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 14, 2004 - 12:40 PM
Ah yes the ST->GT conversion, yeah if you have an S54 tranny obviously your going to need the GT axles, however I was under the impression that the MR2 axles will not fit into the hubs of the Celica and/or they are too short.
This post has been edited by Supersprynt: Oct 14, 2004 - 12:40 PM
post Oct 14, 2004 - 12:58 PM
Consynx
Joined Dec 25, '02
what is dif b/t auto and manual GT trannies, are they both the S54 just with dif gearing?
I take it they use the same axles, so a swap is not necessary, would there be a pt where the GT axles can't handle the extra power?
as for the change for the LSD tranny, would you need the axles from the tranny you got...ie Curren w/ LSD or MR2 w/ LSD...
post Oct 14, 2004 - 1:20 PM
If you have an auto tranny you need auto axles, same goes with manual. The GT is not built to handle the power put out by the 3s, it is basically a crap shoot. Some have died sooner than others, some have gone to 400hp and still kicking. The not-knowing is the biggest problem.
I am unsure what will fit in the Curren tranny, but I was under the impression it was just an S54 with LSD, but I dont know for sure. Either way, you'd need LSD axles for an LSD tranny.
post Oct 14, 2004 - 1:25 PM
Consynx
Joined Dec 25, '02
so if sum1 has auto before the swap, they need manual axles to convert to manual when swapping(along w/ w/e else)
ok...
post Oct 14, 2004 - 1:43 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
dont you need lsd axles to use a lsd tranny?
post Oct 14, 2004 - 1:45 PM
Consynx
Joined Dec 25, '02
QUOTE (Supersprynt @ Oct 14, 2004 - 11:20 AM)
he said it right there you do.
just it seems no1 knows what yet
what i dont get is...can you use the S54 tranny and get the TRD LSD?
that would still be using stock axles, but w/ a Helictical(sp) LSD
edit: with this in mind you should be able to use a regular MR2 Turbo tranny(pre-93) w/ the stock axles, then find a LSD for it...
This post has been edited by Consynx: Oct 14, 2004 - 1:46 PM
post Oct 14, 2004 - 2:09 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
well mina is using mr2 axles so i guess that solves the question.
post Oct 14, 2004 - 2:21 PM
Mina is also using an E153 w/LSD.
I am unsure of the aftermarket LSD systems as they are few and far between. It would probably be cheaper to buy an entire tranny than to buy the TRD one and put it in.
Theres a Curren 3sge tranny up for sale and if you do some research and/or he has the axles you can use that. I am unsure of the compatibility between that transmission and the S54 transaxles.
post Oct 14, 2004 - 2:22 PM
QUOTE (recneps @ Oct 14, 2004 - 2:43 PM)
I think he and I were both referring to the S54 transmission on the N/A MR2's.
post Oct 14, 2004 - 2:30 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
hmm well that makes me feel dumb.
but yeah buying a aftermarket lsd is kinda pointless for the fact that they are all upwards of $700.
post Oct 14, 2004 - 5:51 PM
Consynx
Joined Dec 25, '02
trying to get all the possible combos so i could make a list and get it stickied or somethin
post Oct 14, 2004 - 9:47 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (recneps @ Oct 14, 2004 - 7:30 PM)
That actually depends on how good the Stock MR2 LSD is compared to the aftermarket unit. If the stocker is a 2 clutch LSD... than it's ghey and an aftermarket LSD would be far godlier...
The reason you may need LSD inner axle shafts for the LSD tranny is because Toyota has a bad reputation about their LSD axles being a LOT shorter than their open diff axles. If that's the case, you can always chop the non-LSD axle and make it work... I don't think that is the case however... but who knows.
Aside from that, the only other difficulty would be shift linkages...
Lo-Fi Version Time is now: November 28th, 2024 - 9:20 PM
