> projectors wiring
post Oct 14, 2004 - 10:47 PM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
Is it a big job to change the headlight wiring for projectors?
ne1 also have a how-to or someting?
post Oct 14, 2004 - 11:22 PM
go to autozone and get a 3 pronged H1 connector, take one off and plug it in.
post Oct 15, 2004 - 12:24 AM
slipgun
Joined Jun 2, '03
From Annandale VA
It make take 30 minutes if your a little new to wiring tongue.gif You will need to splice the wires just get some of thoes circular tube crimp things*Im tired and cant remember whjat they are called* from autozone to crimp the wires to the sockets.
post Oct 15, 2004 - 12:33 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
lol...they are called butt conectors..if you are going to use those i would also suggest to get some shrink tubing to put over it to help seal it from water and everythign else that might get in there.
post Oct 15, 2004 - 12:59 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
why not just electric tape the two ends :-p
iunno, i dont like butt connectors.
if soldering what would you use to cover it up afterwards
post Oct 15, 2004 - 1:56 PM
rgyota
Joined Jan 21, '04
I had a custom harness made so I could plug and play. Cost $10 inc. shipping biggrin.gif
post Oct 15, 2004 - 9:38 PM
ROBWOZ1018
Joined Oct 21, '02
From Pittsburgh
I used a 3 prong universal harness...Cut off the existing harness then crimped them using butt connectors...I then used brush on electrical tape to seal it and put protective wire loom over it to protect it...One thing with wiring is just to make sure it stays dry and secure...A small electrical short will give you more than a headache...
post Oct 15, 2004 - 9:58 PM
94silverst
Joined Feb 20, '04
From Washington
If you have stock headlights, what all do you need to purchase with the projector housings? Can you just use your stock bulbs? Or do you have to but like a 500 dollar kit?
post Oct 15, 2004 - 10:44 PM
slipgun
Joined Jun 2, '03
From Annandale VA
H1 bulbs in low's stock in highs.
Lo-Fi Version Time is now: November 29th, 2024 - 11:13 PM
