Toyota Celica GT4 ST185 3SGTE Front clip |
Oct 18, 2004 - 7:29 PM |
Enthusiast Joined Sep 28, '04 From United States Currently Offline Reputation: 1 (100%) |
I am swapping a 3s-gte st185 engine in my 1997 Toyota Celica ST A200 and i was wondering whether to get a gt transmission or a camry transmission. If anyone could give me advise that would be great, thanks.
Oct 18, 2004 - 7:34 PM |
Camry stronger, but taller gear ratios slower acceleration. You can always use the MR2T tranny.
Look arounnd alot of info recently on this subject. -------------------- |
Oct 18, 2004 - 7:40 PM |
Enthusiast Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) |
damnit i knew i was getting screwed somehow!!!... the guy who i bought the car off of put a camry tranny in my celi
-------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
Oct 18, 2004 - 7:47 PM |
Oh I c what you mean, I meant the V6 tranny, he probably used the 4cyl camry tranny which i believe is the same as the GT, but not sure.
If you have the 4 cyl camry tranny its not any stronger than the GT. -------------------- |
Oct 18, 2004 - 8:21 PM |
well ill tell you one thing, the throw out bearings are different on the trannys the camry one is bigger
Oct 18, 2004 - 8:38 PM |
if you want cheap and easy, get a GT tranny. if you want the best, get an mr2 turbo tranny with lsd.
Oct 18, 2004 - 10:38 PM |
hmmm.....I dont think a 4cyl camry tranny will work with the swap. Its only the E-153's in the v-6 camry's and solaras that work. I am about 95% sure - you may want to verify.
Oct 18, 2004 - 10:52 PM |
I thought the 4cy camary tranny is the same engine an tranny as the 5s-fe, isnt it.. like the same exact one and set-up.. but i really have no idea, thats was what i thought though. |
Oct 19, 2004 - 1:06 AM |
The actual tranny should be the same... gearing and final drive may be different though... -------------------- "It's ok to be naked girl... I'm an artist!"
Oct 20, 2004 - 8:04 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
I know that with the Corolla, there's a problem using the MR2 tranny because the shifting linkage where the cables connect is on the wrong side. They can be switched but it's a lot of work. Wouldn't it be better to use the V6 Camry tranny then? He could always add a Quaife down the road.
Or will the the 3SGTE MR2 tranny work just fine? This post has been edited by raven_101: Oct 20, 2004 - 8:04 PM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Oct 21, 2004 - 3:38 PM |
Enthusiast Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
I have a tranny with LSD that will bolt right up!(JDM)
Lo-Fi Version | Time is now: December 3rd, 2024 - 6:08 PM |
