> Need help finding wiring harness
post Mar 12, 2003 - 9:05 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
Okay, I'm looking to replace the factory stereo in my 99GT and before I went and bought a wiring harness I wanted to make sure the connections were right by looking at the plug configuration. So after much aggravation I FINALLY got to the factory amp and pulled out the wiring harness to see what the plug looks like. The problem is that I've seen a wiring harness for Toyotas 1987-up and it looks NOTHING like the wiring harness I pulled out of the factory amp. Does anyone know if there is a harness that fits my connection? By the way, here's a description of the plug pin alignment. The top row: group of 2, group of 2, plug tab, group of 2, 1 pin. Bottom row: group of 2, group of 6, 1 pin. Thanks for any help!
post Mar 12, 2003 - 10:34 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
Are you looking at the blue or white plugs. You need the white ones. They are a little hard to get at. And yes all celicas from 87 up are the same harness.
post Mar 12, 2003 - 11:12 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
I'm looking at the white plug. There are only 2 plugs that I see, the one that comes from the stereo that plugs into the amp and a larger one that plugs into the other end of the amp. The last one is the one( I assume) that is the factory wiring that I need to connect a new head unit to. And yes, it was a challenge to get to this plug.
post Mar 13, 2003 - 4:49 PM
AudioFreak
Joined Dec 19, '02
Sounds like you got it figured out.
post Mar 13, 2003 - 11:10 PM
95STCelica
Joined Oct 12, '02
From New Jersey
i got a wiring harness from this local tire place oddly enough they stock like three car audio things and it just happened to be a wiring harness that works with my car
post Mar 14, 2003 - 6:42 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
QUOTE (95STCelica @ Mar 13, 2003 - 9:10 PM)
What was the harness for to begin with?
This way there are alternatives to strictly toyota celica wiring harnesses.
post Mar 14, 2003 - 12:25 PM
runriot95
Joined Dec 1, '02
From Pittsburgh, PA
- Does this harness have the pin alignment like I described here? -
Lo-Fi Version Time is now: November 25th, 2024 - 1:59 AM
