> Valve cover thing, won't stay done... why?
post Mar 12, 2003 - 9:22 PM
Benevolence
Joined Oct 9, '02
From San Diego, CA
Then 2nd valve cover of 4 keeps popping up every so often which results in a low idle'ing and a choppy ride if below 2k rpm. So I messed around with it and for some reason its much looser than the other three covers, does anyone know how to remedy this? Gets annoying to have to push it back down every so often. Thanks for the comments.
post Mar 12, 2003 - 9:39 PM
Charlie97L
From North Bethesda, MD
what do you mean by valve cover? like the spark plug wire keeps popping up? how do you notice if it's in the engine bay?
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Mar 12, 2003 - 11:37 PM
Benevolence
Joined Oct 9, '02
From San Diego, CA
QUOTE (Charlie97L @ Mar 12, 2003 - 7:39 PM)
yeah,well, my car was running crappy a few weeks ago, so I popped my hood and saw it popped up half way and i pushed it down and it was running good again but now it frequently pops up and is looser than the other ones.
post Mar 13, 2003 - 12:11 AM
FallenHero
Joined Dec 26, '02
From Alabama
try to crimp down the end of the plug wire. If it keeps hapening, just get new wires, it's a good thing to do, you know....
post Mar 13, 2003 - 1:04 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
did u recently change ur spark plug wires? cuz if you did then your problem is that the rubber boot off of you old ones is stuck down in ur head and that is a bish to get out.. I had to take the head off to get at it... otherwise just try crimpin it like fallenhero said
post Mar 13, 2003 - 2:57 AM
Benevolence
Joined Oct 9, '02
From San Diego, CA
Thanks for the advice, I have been "crimping" it. It stays down for a few days but slowly makes its way up, I guess I need a new wire. rolleyes.gif
post Mar 14, 2003 - 12:03 AM
FallenHero
Joined Dec 26, '02
From Alabama
Unless I'm mistaken, TRD makes wires for the 7A and the 5S
post Mar 14, 2003 - 6:08 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
TRD wires are hella expensive. If your gonna get new wires you might as well get some that will help you out with voltage and stuff. Check the parts database.
Lo-Fi Version Time is now: December 4th, 2024 - 8:10 AM
