> neons, fusebox, toggle, what is the wiring for this project
post Mar 12, 2003 - 11:04 PM
Zasper
Joined Mar 12, '03
From shippensburg, PA
can someone help me with which wire goes wear and why it wont work when i do it.........thanx.
post Mar 13, 2003 - 12:49 AM
NoVa
Joined Nov 12, '02
From Tucson
if your talking underbody neon, mine came with a fuse and a transformer. I ran them direct from the battery, only problem I know of is if you dont have all of them connected properly, IE wired right, they wont turn on or will flicker, because they are in series and the others wont close the circuit. Other than that I dunno
post Mar 13, 2003 - 4:04 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Only problem with hookin it straight to your battery is draining the battery dead. If you hook it to your fuses, then it runs off your alt.
post Mar 13, 2003 - 11:41 AM
Zasper
Joined Mar 12, '03
its for interior neons, but i heard that it can mess up your cars computer if you run it to your fuse box, does anyone know anything about that?
post Mar 13, 2003 - 3:22 PM
95STCelica
Joined Oct 12, '02
From New Jersey
i haven't heard anything like that?
I have mine wired to the battery.
post Mar 14, 2003 - 12:44 AM
FallenHero
Joined Dec 26, '02
From Alabama
Just run a wire to the cigarette lighter positive side. Then ground it and you'll be great.
post Mar 14, 2003 - 5:37 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
QUOTE (FallenHero @ Mar 13, 2003 - 10:44 PM)
If you do it that way then they will come on everytime you start your car.
If you only want them on during the night, hook it up to your dimmer switch and they will only come on when you turn your lights on.
post Mar 15, 2003 - 5:56 PM
Inferno
Joined Jan 30, '03
From Virginia
I have a question about the underbody kits. In my state(if not in all), it is illegal to run underbody neons while driving down the road. It's legal while sitting parked or whatever, but not while driving. I was wondering if there was a way to custom hook it up so you could have a switch to turn it on and off, like as if you were parked and went to driving,you could flip the switch and cut it off.
post Mar 18, 2003 - 12:27 AM
FallenHero
Joined Dec 26, '02
From Alabama
yea, just splice in a switch from your positive lead wire.
post Mar 18, 2003 - 1:46 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
Here in kansas it's legal to have them on the side of the car. But if they are on the front or back then it's illegal. Totally ghey i think.
post Mar 19, 2003 - 8:33 PM
freestyler121
Joined Sep 28, '02
From Lancaster Ca
you can hook it up to a swith, this is how you do it, one wire goes to one side of the swith, that wire is from the neons, the other side runs to the battery, its just a relay switch, can be picked up for 2 bucks if that, my friends hooked it up to his crx
Lo-Fi Version Time is now: December 1st, 2024 - 1:06 PM
