> 3sgte info, just a little something about the tranny
post Mar 13, 2003 - 1:02 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
just though you guys might be interested in knowing that the 3sge transmission will work in the 6th gen with a 3sgte bolted on and its alot stronger than the GT transmission.. I stumbled across that a little while ago and called toysport to confirm it and they told me that's the transmission they now use for there swaps.
post Mar 13, 2003 - 1:05 AM
1bwilson
Joined Aug 30, '02
From Maryland
So would you say that you could also use the 3sge tranny on a built 5sfe?
-Bryan-
Member of Team 5sfTe
post Mar 13, 2003 - 1:12 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
thats a good question.. I dont see why not but I also dont really see the purpose of doing that as you would have to dump thousands into the 5sfe to require a stronger tranny
post Mar 13, 2003 - 1:21 AM
zigy
Joined Nov 6, '02
From Chicago, IL
So you think that it actually matters which transmision you are going with,
hmmm, I don't think so, why ??? I'll let you know why???
"Jspec/US-Spec MR-2 Trans" vs "US-spec GT Trans"
What do you think, whoever had that turboed MR-2, was driving the car
SLOW, hell no, anyone with a turboed car would beat the living crap out of it.
So you do get better transmision with MR-2 overall but the condition of the
MR-2 trans versus pure stock US-spec GT cannot be compared...
***** so if you compare pros and cons it kind of equalls out *****
95STCelica
Joined Oct 12, '02
From New Jersey
all i know is that the tranny from the AT200 is crap, well atleast that's what has been said on this board..
post Mar 13, 2003 - 1:44 AM
1bwilson
Joined Aug 30, '02
From Maryland
The GT tranny will max out at about 250hp at the most. However the duce turbo and solara v6 tranny should hold around 350-400 hp with out a problem so wether or not the trannys took a beating or not they should be able to take the abuse. The 3sge tranny I assume is built with the same standers as the 3sgte tranny (excluding the awd) if so that means that you can push the tranny a little harder.
NEway I am planning on getting my 5sfTe project going so I should be at 200-220 hp by summer so we'll see what the gt tranny can handle then biggrin.gif
-Bryan-
post Mar 13, 2003 - 2:29 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
What kind of tranny do they use on the 700hp+ on the 3sgte project cars?
I know it ain't the original tranny.
post Mar 14, 2003 - 12:04 AM
FallenHero
Joined Dec 26, '02
From Alabama
I've heard that the AT200 can handle up to about 200. That right?
post Mar 14, 2003 - 12:32 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
I dont know about u but I think after spending all of the money to purchase a 3sgte and swap it in and all that the transmission choice would be pretty important...
lets pretend for a minute that the transmission isnt one of the MOST IMPORTANT parts of the drive train...
bolting up a transmission that is rated at 200-250hp isnt gonna last very long on an engine that ranges from 200hp up wards to 350hp on some versions - thats like makin a spacestation outta gumdrops and toothpicks - only one STUPID muthafuker is gonna think that it has a chance..
who know maybe u just like burnin up trannys... or maybe you've neverdone it and dont have a clue how much of a pain it is to replace/rebuild a transmission.
Point is I was just offering up another option on the 3sgte swap and it a pretty good option at that
post Mar 14, 2003 - 12:49 AM
boosted_K2
Joined Aug 30, '02
From Michigan
how hard would it be to source a 3sge tranny though?
This post has been edited by K2_Celica: Mar 14, 2003 - 12:50 AM
No but I don't buy it
Cause I'm...
post Mar 14, 2003 - 12:56 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
u can get them form the same kinda places that have 3sgte's
post Mar 14, 2003 - 5:26 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
If you can find a 3sge front clip, odds are that you can get the tranny with it also. Along with the axles and whatnot that is also needed for a swap.
post Mar 15, 2003 - 12:36 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
where talkin about using the 3sge transmission with the 3sgte engine.. of corse the 3sge clip will come with the tranny,ecu and harness
Lo-Fi Version Time is now: November 29th, 2024 - 5:45 AM
