Consoles... |
Consoles... |
Mar 13, 2003 - 3:50 PM |
Enthusiast Joined Feb 22, '03 Currently Offline Reputation: 0 (0%) |
How do you take out all the consoles and plastic pieces in the interior?? I gotta 96 celica and i cant find any of the screws or anythin....frustrated...need help...can anybody help me out???
-------------------- Note to new members. Discussions such as the ones below are forbidden.
http://www.6gc.net/forums/index.php?showtopic=26310&hl= |
Mar 13, 2003 - 4:27 PM |
Enthusiast Joined Oct 9, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
I think you just pull them out with brute strength.
Mar 13, 2003 - 4:44 PM |
Enthusiast Joined Dec 19, '02 From West of Atlanta Currently Offline Reputation: 1 (100%) |
consoles? The center console. Start inside the storgae under the armrest. 2 i think 12mm bolts. That frees the back half the front edge of it slides up and then back out at the joint near the shifter. This then uncovers a screw on each side of the next piece.
The trim around the shifter just snaps in. Once it's out there are 2 screws at the bottom of the panel below the heater controls. Take them out and the rest of that panel just pop out. Below the dash it's screws and 10mm bolts. There is a screw hiding behind the kick panel. You gotta take off the door sill (it pops off) to get the kick panel out. Take it easy on the panels that pop off it dosen't take much to get them out. |
Mar 13, 2003 - 11:14 PM |
Enthusiast Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
Start at the bottom and work your way up, and don't lose any screws. And be gentle or you will regret it later
Mar 14, 2003 - 12:15 AM |
Enthusiast Joined Oct 1, '02 From Minnesota, USA Currently Offline Reputation: 0 (0%) |
Well, the center console's easier than said before. Turn your key to on...put the emergency brake up and if it's an auto....shove it in neutral...now twoards the bottom of that plastic piece....close to the ashtray or whatever....just oull up...it comes up....and that piece has no screws in it. The next piece has screws in it though. The hardest part I found was trying to get the next center piece to come out as there si the clock and the vents and the hazard light switch in the way.
-------------------- 95 Toyota Celica GT
Mar 14, 2003 - 5:55 AM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
A thin flat-head screwdriver comes in real handy when removing pieces that are held on with clips.
Lo-Fi Version | Time is now: November 28th, 2024 - 7:54 PM |
