> engine mounts
post Oct 24, 2004 - 3:56 PM
62-1celi
Joined Sep 14, '04
From miami
can i use the 93 5s-fe engine mounts on my 96 st....want to do the swap
post Oct 24, 2004 - 5:52 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
what engine are you trying to put in.
theyll fit any S seris engine.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 24, 2004 - 6:04 PM
Sev408
Joined Dec 4, '03
well that answered your question, a 7afe isnt a s series engine.
i THINK only 2 or 3 of them work, i think the transmission side mount will not work.
user posted image hows it taste motha f*cka
post Oct 24, 2004 - 10:58 PM
62-1celi
Joined Sep 14, '04
From miami
to do the 3sgte swap you can use the 2.2 engine mounts.......i have a 96 1.8 ........what im goin to do is put the 3s with the 5s tranny......now what i need to know is if i could use the 93 5s-fe engine mounts( reson being is that my local u-pick-it has like 6 or 7 5th Gen..........cand if you need a part off the 5th Genlet me now
This post has been edited by 62-1celi: Oct 24, 2004 - 11:06 PM
post Oct 24, 2004 - 10:59 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
yes to swap a 3sgte into your st your going to need 5sfe(gt) engine mounts.
post Oct 25, 2004 - 2:35 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
You can get new mounts for the 5S block from this site: http://www.toyotaandlexusparts.com/
They have just about every single stock part, body or mechanical, for all 6gcs.
This post has been edited by CheesyLobster: Oct 25, 2004 - 2:36 AM
post Oct 26, 2004 - 7:24 PM
TOYOCE409
Joined May 14, '04
From Port Arthur. TX.
I got the passanger side mount for sale on ebay if you are interested.
post Oct 28, 2004 - 5:17 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
To answer your question. I do not think that you can use the 93 gt passenter side mount b/c the celica body is different. I did the swap and remeber that the mounts looked different from the 93 to 94-99 model. The front and rear mounts will be the same. The driver's side might be the same, but I'm almost positive that hte passenger is different. This mount will bolt in the same spot on the frame but the 94+ then bolts to the strut tower and the 93 and lower does not. Go to the dealership and have them bring up the diagrams on their computer.
Lo-Fi Version Time is now: February 18th, 2025 - 4:45 PM
