> Grinding in 3rd gear
post Mar 14, 2003 - 12:21 PM
skippy344
Joined Mar 14, '03
From College Station, Texas
Hey Folks,
I just replaced my original clutch at 131K mi. I installed an Exedy Sportline clutch Kit. Resurfaced the Flywheel and used the same oil that the dealership uses.
Now, when cold, its hard to shift into 1st, and when shifting into 3rd, all the time, it grinds a little.
I did not grind before the clutch replacement, but the original clutch was slipping, so that 's why I replaced it.
Any ideas about why its hard to shift into 1st and grinds into 3rd?
Thanks,
post Mar 14, 2003 - 2:51 PM
boosted_K2
Joined Aug 30, '02
From Michigan
No but I don't buy it
Cause I'm...
post Mar 14, 2003 - 3:35 PM
95STCelica
Joined Oct 12, '02
From New Jersey
that is not funny at all..i am on 131,886 miles..and i don't want to change my clutch...not yet at least frown.gif
post Mar 14, 2003 - 5:02 PM
post Mar 14, 2003 - 5:37 PM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
I take it that you changed the clutch yourself, which for starters was probly a no no! thumbsdown.gif
post Mar 14, 2003 - 9:05 PM
stelica85
Joined Jan 16, '03
From Wichita KS
I have the same problem with third, It is harder to get in than any other gear and it sometimes grinds especially when its cold.
someone told me it was the syncros to.
don't know what i can do about it and not end up spending alot of money.
post Mar 14, 2003 - 9:18 PM
GTS_Bun
Joined Oct 21, '02
From Toronto, Canada
Try changing the manual transmision fluid, it may not solve the problem entirely, but it should reduce the grinding.
post Mar 14, 2003 - 10:17 PM
boosted_K2
Joined Aug 30, '02
From Michigan
if it happens too often that means its a syncro problem, you may need to have the tranny redone. i had to have mine redone at 70K miles... luckly it was under warranty.
Cause I'm...
post Mar 24, 2003 - 9:04 AM
0Re0
Joined Nov 13, '02
From Hawaii
Same as my friends turbo'd civic. 3rd always grind. Thats why he jumps from second-to-fourth then third-to-fourth again.
post Mar 24, 2003 - 5:09 PM
PdiddyGT
Joined Mar 18, '03
From Salt Lake City,Utah
Hey man consider yourself luck mine is grinding into 3rd and it only has 86000 miles on it tell me if you find a solution. biggrin.gif
post Mar 24, 2003 - 5:38 PM
96cel_John
From PA
yeah, its like hard for me to downshift into first when im moving really slow. i pretty much have to come to a complete stop to shirft into first.
post Mar 24, 2003 - 9:42 PM
boosted_K2
Joined Aug 30, '02
From Michigan
people dont like to listen...
ITS A SYNCRO PROBLEM
Cause I'm...
post May 21, 2003 - 12:18 PM
skippy344
Joined Mar 14, '03
Alright folks, I think I'm gonna break down and take it to a Tranny shop and let them give me the bad news about cost to fix the grinding/not going into gear problem.
I'll let you folks know what they say.
post May 21, 2003 - 12:25 PM
Rivo
Joined Apr 28, '03
Yeah, I got 157k miles on mine and 3rd has been grinding for the past 50k tongue.gif It just recently got bad where I could be sitting at a light and it would try to go into 3rd with my hand resting on it. I changed the clutch fluid a few weeks ago (was all black and burnt) and it's been diminished significantly. Also, there are like 2 ways to put it in 3rd. I found that if I shifted just a little bit more the right when putting it in 3rd, it didn't grind. Just a thought.
post May 25, 2003 - 2:45 PM
TigerWoodsJr
Joined Nov 13, '02
From Bangor, Me/ Huntsville, Alabama
synchros.....double clutch....
post Jun 5, 2003 - 12:55 AM
kyle314
Joined Nov 4, '02
From montrose colorado
mine starting to do in 3rd, its got 61,000k. i'm going to look for TSB's when i get to work and see if toyota had a problem with the 6th gen's trans i'll let u know what i find. and yes it does sound like synchros, but its kinda weird that we r all having the same problem. if i don't find anything in the TSB's i may call tech line.
post Jun 5, 2003 - 8:25 AM
TurboGT14PSI
Joined Jun 4, '03
From KY
i put 139k on my original cluct/tranny...never had a 3rd gear problem, and i drive min elike i stole it and am making a run for the border
post Jun 5, 2003 - 9:48 AM
slipgun
Joined Jun 2, '03
From Annandale VA
I just bought my celli its got 52k miles and its doesnt like to go into 1st gear if im goin about 5mph.... I thought toyotas just did that? Dont tell me somins goin at 52k miles! redface.gif
post Jun 5, 2003 - 7:55 PM
robman5
Joined Nov 3, '02
From mass
yup same here, 110 000 miles, wont go into first gear unless im barley moving, second i have to jam in pretty hard, and 3rd geear grinds a bit sometimes, gonna have to try changing the tranny fluid, although i just got a new clutch, so was it changed?
post Jun 6, 2003 - 5:26 PM
TigerWoodsJr
Joined Nov 13, '02
does it work when you guys rev match 1st?
Lo-Fi Version Time is now: November 28th, 2024 - 12:36 PM
