> Handbrake Adjustment, How to do it
post Oct 27, 2004 - 8:21 PM
gnetik
Joined Aug 14, '04
My handbrake has to be pulled up way too high for it to take effect. I want to adjust it down to like 4-5 clicks. Does anybody know how I can adjust the hand brake? Thanks
post Oct 27, 2004 - 8:30 PM
shadycrew31
Joined Jun 29, '03
From canoga park , ca
yea theres a lil bolt to the right side of the handle just tighten it or loosen it to your specs. to get to it just push the rubber fitting that goes around the hand brake aside.
post Oct 28, 2004 - 9:32 PM
Junior
Joined May 5, '03
From Toronto
QUOTE (shadycrew31 @ Oct 27, 2004 - 6:30 PM)
that is one way to do it, but the proper way to do it would be to take off the rear rotors/drums (depending on what you have) and adjust the adjuster. If you have an ST, this is definately the way you wanna do it.
post Oct 28, 2004 - 11:42 PM
ShadowFX
Joined Jan 22, '04
From WA, Australia
what about for a GT?
post Oct 29, 2004 - 1:01 AM
idriveatruckWTF
Joined Sep 18, '02
From San Diego, CA
QUOTE (Junior @ Oct 28, 2004 - 7:32 PM)
What exactly is the adjuster? Is this a "do it yourself" job?
[toyota]
post Oct 29, 2004 - 3:10 AM
shadycrew31
Joined Jun 29, '03
ehh i like my way i can do it well i drive!
post Oct 29, 2004 - 10:29 AM
Junior
Joined May 5, '03
From Toronto
QUOTE (shadycrew31 @ Oct 29, 2004 - 1:10 AM)
do it my way and you'll brake faster. There will be less travel in the brake pedal.
post Oct 29, 2004 - 10:30 AM
Junior
Joined May 5, '03
From Toronto
the adjuster is a little spindle on the bottom of the e-brake assembly. If you've never done it, let someone take you through it the first time. After that you should be good to do it when ever you want.
post Oct 29, 2004 - 4:14 PM
gnetik
Joined Aug 14, '04
QUOTE (Junior @ Oct 29, 2004 - 3:30 PM)
what exactly is the difference between the two methods of adjusting the handbrake? Is one better or safer than the other? I'd probly do the easier way, but if there is something wrong with just adjusting the spindle, then I would do the other method. Enlighten me more... thanks!!! smile.gif
post Oct 29, 2004 - 11:15 PM
Junior
Joined May 5, '03
From Toronto
adjusting at the hand brake itself only adjusts the cable. If you got rear drums, the shoes are actually used when braking. If you adjust at the brakes, you're actually moving the shoes closer to the drum, and this will result in a better response in your brakes.
post Oct 30, 2004 - 1:11 AM
gnetik
Joined Aug 14, '04
QUOTE (Junior @ Oct 30, 2004 - 4:15 AM)
So it would be ok for me to just adjust the spindle/cable since my rear are not drums?
post Oct 30, 2004 - 1:42 PM
shadycrew31
Joined Jun 29, '03
ctually for the e-brake there rear drums on both models the gt has a rotor. but if you rip up that e brake theres a lil drum behind the rotor.
post Oct 30, 2004 - 6:11 PM
spunky393
Joined Apr 22, '04
From illinois
So how do we go about doing this on a GT with out messing with the inside of the car. Like, what bolts need to be removed, where are these bolts (i just came inside, and there is only one bolt on the bottom side holding the caliber, and i can't find the other one) and what else needs to be done.
post Nov 1, 2004 - 5:39 PM
gnetik
Joined Aug 14, '04
Yea, i'm just as stuck as spunky...., anybody have any input?
post Nov 3, 2004 - 10:03 PM
johnnyjayzee
Joined Feb 19, '04
From San Francisco
hey i wanted to also tighten up my e-brake. by reading this im still not sure on which method to do. i think i will just adjust the cable by the handle. is it that simple to do???
post Nov 5, 2004 - 3:09 AM
gnetik
Joined Aug 14, '04
Can someone give us some full and clear directions on how to adjust the handbrake from the wire/spindle?
post Nov 5, 2004 - 7:51 AM
tufy
Joined Dec 3, '03
From Cyprus
first adjust hand brake level that you want when its on. then screw this adjustment blod as you can. you may need a special tool. or if you can remove that plastic cover betwen seats it would be easier
This post has been edited by tufy: Nov 5, 2004 - 8:02 AM
post Nov 5, 2004 - 11:14 AM
dabbill
Joined Aug 26, '04
From Vancouver, WA
if the black rubber was a pink color that would look really wrong. Sorry had to say it.
post Nov 5, 2004 - 5:18 PM
gnetik
Joined Aug 14, '04
post Nov 5, 2004 - 6:35 PM
shin
Joined Aug 21, '04
From New York City
so how's this suppose to work? the tighter you screw it the harder the ebrake is? confused.gif
~*MuH NeW RiDe*~
Lo-Fi Version Time is now: November 28th, 2024 - 7:51 AM
