Help with removing front rotors, I don't know the size of a nut |
Oct 28, 2004 - 4:41 AM |
Enthusiast Joined Sep 18, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
I went ahead and started to remove the front brake rotors, but there's a big nut holding it on. Does anyone know what size that nut is, so I can go to the autostore and buy the socket..
-------------------- [toyota]
Oct 28, 2004 - 7:04 AM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
Is that the axle nut you are talking about? I think its 32mm... Im not positive though let someone else confirm. And if you dont have one, i suggest getting a breaker bar too. That nut is a bitch to get off.
Oct 28, 2004 - 10:10 AM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
the big nut is 32mm, but do not take it off. That is the axle nut, you don't need to remove it to get your rotors off. Just take the calipers off and pull. You might have to convince it with a hammer. Just smack it a couple time to loosen the rust.
Oct 28, 2004 - 2:41 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
yep rotors will come without taking that nut off and yes it's a 32 mm
This post has been edited by rjbibeau: Oct 28, 2004 - 2:42 PM -------------------- |
Oct 28, 2004 - 6:35 PM |
Thanks a lot guys!!! That's all the advice I need. Thanks a bunch.
Oct 28, 2004 - 7:09 PM |
Enthusiast Joined Jun 29, '03 From canoga park , ca Currently Offline Reputation: 0 (0%) |
i dunno if this was said but umm. you dont need to remove anything but the wheel. if there stuck go to auto zone and get a claw puller thing to pry it off(i forget the name of the tool). i had to on mine.
Lo-Fi Version | Time is now: November 28th, 2024 - 9:53 PM |
