> 3sgte down pipe, stock or aussie
post Oct 30, 2004 - 7:58 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
any one use a stock elbow wit out midpipeor hollow midpipe ,or assuie down pipe wich is better???
post Oct 30, 2004 - 8:32 PM
jgreening
Joined Jan 17, '04
From Illinois
if you use an aftermarket downpipe, you will likely have boost creep issues unless you use a turbo with an external wastegate. The Aussie is a good unit if you go that route and if you KNOW you will not be going over 275whp, you could get the 2.5" ko downpipe. I kept the stock cats and b-pipe for boost creep in noise issues but it is a fairly significant power bottleneck.
Lo-Fi Version Time is now: December 2nd, 2024 - 8:45 AM
