> Rear Brakes GT (ASAP PLEASE), Getting them off
post Oct 31, 2004 - 11:13 AM
spunky393
Joined Apr 22, '04
From illinois
I'm having trouble getting my rear brakes off, it isn't like a honda or any other american car where there is two bolts, one on the bottom side of the caliper, and one on top. But on the toyota GT, there's only one on the bottom. Um.....so how do i get it off? THANKS
post Oct 31, 2004 - 11:21 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
there are two bolts. One on top and bottom of the caliper... If there is only 1 bolt, you are missing one. Just remove the bottom one and the cliper will slide off. THen use a bolt to screw in to the small holes on the rotor to pop it off
Jeremy
post Oct 31, 2004 - 5:21 PM
spunky393
Joined Apr 22, '04
From illinois
no, one is not missing, on my GT brakes, there's a bolt on the bottom of the caliper, but on top, it's a rubber grommet of some sort.
post Nov 1, 2004 - 12:43 AM
Jeremy1210
Joined Dec 16, '02
then there is something wirn with your calipers, I swapped my rears to GT's and they are both bolts that hold the caliper to the backing plate. I guess take it to the dealer if you can't get it off
Jeremy
post Nov 1, 2004 - 1:18 AM
Sterjs
Joined Oct 21, '04
From Austin, TX
QUOTE (spunky393 @ Oct 31, 2004 - 4:21 PM)
Just remove that one bolt and lift the caliper. You still need to remove 2 other bolts in order to remove the rotor and the pads behind the rotor.
'99 Convertible
post Nov 1, 2004 - 1:49 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
There's 2 pieces. If you want to remove the caliper... remove the two bolts on the caliper bracket... not on the caliper itself. There's only one bolt on the caliper (bottom) and a sliding pin on the top.
post Nov 1, 2004 - 10:46 PM
spunky393
Joined Apr 22, '04
From illinois
how does the sliding pin work? i'm just trying to get to the brake pads
Lo-Fi Version Time is now: January 11th, 2025 - 7:00 AM
