3 Pages V   1 2 3 >
Closed TopicStart new topic
> body roll
post Nov 5, 2004 - 2:02 PM
TRD-ST204
Joined Sep 26, '04
From Sacramento, California
My GT has a lot of body roll, it occurs even when turning slightly. On several occassions the rear has broke loose because of the weight transfer. What are some good parts can I buy to make it go away. Also I have a lot of ground clearance can anyone help me out?
post Nov 5, 2004 - 2:15 PM
Gilbert_619
Joined Sep 10, '04
From san diego
the best way is to cage it up i think....
or just get new shocks..lower it and struts it up too
post Nov 5, 2004 - 2:49 PM
dabbill
Joined Aug 26, '04
From Vancouver, WA
Coilovers will help alot. Droping my car about 3 inches with some coilovers off ebay took a lot of the body roll out.
post Nov 5, 2004 - 3:53 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I think some springs or such would help a ton. Also, You could try some sway bars... Thats what there made for, but i would do the springs first.. or do it all at once..
post Nov 5, 2004 - 4:08 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
3 inches no way did you lower it that much. i slammed mine like 2.25 and i have like no suspension.
post Nov 5, 2004 - 4:55 PM
TTE
Joined May 19, '03
From NJ
I think in your case your shocks need replacement. I know that I've been there
post Nov 5, 2004 - 5:04 PM
dabbill
Joined Aug 26, '04
From Vancouver, WA
I have no suspention left. I went from a 3.5 inch gap over my old wheels to a .5 inch gap over the same wheels.
post Nov 5, 2004 - 11:35 PM
coilovers with koni adjustables will do very good...
suspension technique sway bar kit will do REALLY VERY Good
strut tower bars in the front and back and you are completly set
post Nov 6, 2004 - 1:54 AM
Junior
Joined May 5, '03
From Toronto
sounds like you need some shocks and springs. Your sway bar link bushings may also be shot.
post Nov 6, 2004 - 12:11 PM
Mike
Joined Oct 22, '02
From Toronto
New tires too, with a bigger contact patch
post Nov 6, 2004 - 3:41 PM
shadycrew31
Joined Jun 29, '03
From canoga park , ca
get new springs and shocks. that should bring it to better than stock. then get the suspension tech sway bars off nopi for like 250. but only get the sway bars if you wanna go crazy with handling. if you just want the best pakge for your cash get the kyb struts and springs. i prefer sprint. but ya know.
post Nov 6, 2004 - 5:11 PM
Just what everyone said already.
also, the cheap way out would be strut bars and change the rear sway bar bushings and links.
post Nov 6, 2004 - 9:47 PM
frosty
Joined Sep 1, '04
From Alabama
CLOSED on 25 acres!
-shop coming soon....
post Nov 7, 2004 - 12:52 AM
^basically what he should do......if your goin to do it you might as well do it right the first time...
priority order is as follows
1) springs
2) shocks
3) sway bars and bushings
4) strut tower bars (front and back)
post Nov 8, 2004 - 12:16 AM
Akimbo
Joined Jun 30, '03
From O-town, FL
Links for sways bars, bushings, and strut tower bars?
- Ryan
aim: rkgreen04
post Nov 8, 2004 - 12:44 AM
stcivickiller
Joined Jul 14, '04
From pa
well for starters coilover off of ebay are probebly ur worst choice if u wanna do it right go with some eibach springs or some H&R springs something nice or if ur gonna do coilovers buy nice ones or the real deal ture coilovers u could also go with strut bars front and rear sway bars u really only need a rear sway bar and a 3pt. stress bar in the rear helps caging it would tighten it up but its kinda of an extreme solution some good tires would help keep traction too
post Nov 9, 2004 - 2:00 PM
TRD-ST204
Joined Sep 26, '04
Thanks for all your replies it helps me out a lot. I heard the TRD springs were really "good." What exactly can I expect from it.
post Nov 21, 2004 - 7:01 AM
shadycrew31
Joined Jun 29, '03
sorry for bringing up a dead topic but trd's i hear do an inch all around. there stiff but so are sprints and tein's. in the end its your call. but keep in mind that eibach make's trd's springs so yea. good luck!
post Nov 21, 2004 - 2:35 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
eh-hem, do not buy sustension techniques sway bars, those were the only option up until last week when we got deals w/ C-One
do a search, the C-One sway bars should show up, i believe $200ea.
not sure.
As for a springs, anything works well
TRD drops the same amount as S-Tech
there's 1 set of springs that does a lower front than back
Eibach sportlines are more performance based than pro-kit so using them might lead you into buying new struts/shocks as well to keep the ride smooth.
if you go to the links on the main page, i found out most of my info from the Henry site, granted it isn't 100% up to date, it's still a decent site.
post Nov 21, 2004 - 9:43 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
First off... the rear-end of a FWD car can't break out/loose or whatever unless you're yanking on the e-brake. Body roll is due to soft suspension parts... If you're at stock height, worn out shocks can cause increased body roll. I don't reccomend putting money into sway bars unless you're gonna race your car every now and then... as in going to the track and running autoX (not street racing). Lower springs will help... but they're not the problem. The shocks are the problem. Bushings can also be a culprit... but they usually don't completely change a car's handling characteristics when they go bad. Strut bars are mostly to look pretty... cause unless you're gonna race (like mentione above)... they don't help much. That's about it...
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: November 25th, 2024 - 1:34 AM
