> Boost Problems, Greddy Profec B
post Nov 10, 2004 - 6:55 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
ok guys heres my prob. i installed a Greddy Prefec B into my car today.... As soon as i react .2 bar the engine cuts off till i let off the gas .... any suggestions????
-DMC
post Nov 10, 2004 - 8:19 PM
sounds like you are hitting fuel cut.
did you disconnect and plug the Tvis? you can not correctly control the boost with that line still hooked up. im not sure what .2 bar is in psi. but stock fuel cut should be around 12-16psi depending on what year your motor is.
post Nov 10, 2004 - 8:23 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
.2 bar is equivalent to about 3psi
it's roughly 15psi for every bar
post Nov 10, 2004 - 8:24 PM
CEL coming on?
post Nov 10, 2004 - 8:25 PM
yeah pull the CEL codes and see what they tell u.
post Nov 10, 2004 - 8:52 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
problem solved thanx supersprynt
post Nov 10, 2004 - 9:20 PM
so, what was it?
post Nov 10, 2004 - 10:04 PM
Consynx
Joined Dec 25, '02
im curious too!
Lo-Fi Version Time is now: February 22nd, 2025 - 10:18 PM
