> GT4 ST205 Boost Help!!!!!~, help me with boost
post Nov 15, 2004 - 1:01 AM
BGT4
Joined Jun 25, '04
From Christchurch, New Zealand
I am getting a boost controller.
now, can someone tell me what is the boost level for a stock st205? i did a dyno on mine... it showed 13psi. is that right?
now if i get a boost controller how much can i boost? what is the MAXimum boost and wont damage my ST205? How much are u boosting for ur GT4? I had done manifold and full exhaust. 1.5" manifold pipe, 2.5" downpipe and 3" full exhaust.
Help. getting the boost controller in days.... HOW much should i boost it?
post Nov 15, 2004 - 8:57 AM
Stock boost is 12 but because you have increased exhaust your seeing 13psi. Now I hope that you have an aftermarket gauge before you get this boost controller because if you rely on the factory gauge, ur a dumbass.
I would recommend checking on the GT4oc.com boards about the 3rd Gen since it was never here in the states so we dont really have much experience. A few of the guys from across the pond can help though.
post Nov 15, 2004 - 12:59 PM
post Nov 15, 2004 - 5:28 PM
spewie
Joined Oct 16, '04
From The Netherlands
if you get a boostcontroller, you can read out what your boost is, so why use a boost gauge if you are getting a boostcontroller?
i use the AVC-R, self learning mode is even easy to use, but its probably best to get it professionally tuned, especially if you use a different ECU.
Stock i think the ST205, has like 0.65 bar?
I used to run mine on 1.25 bar, which was its total limit.
If I were you, I would not boost it more than 1.0 bar, peaking to 1.15 max.
post Nov 16, 2004 - 12:12 AM
BGT4
Joined Jun 25, '04
yes, i am getting a boost gauge. it will be installed at the same time as the greddy-E01. i was talking to some people working in toyota. they recon i would boost it just before the fuel cut. .... any idea when does the fuel cut kick in? they think i might be able to boost at 16 - 18 psi, what do u guys think?
i think boost controller could be my last upgrade....
post Nov 16, 2004 - 7:56 PM
Mr_E
Joined Nov 16, '04
From UK
Stock boost on a ST205 is just under 14psi. You have fuel maps for 17.5 psi, and the stock engine should be ok until around there (unless you drive like an utter idiot).
Beyond that, and you're into the land of fuel cut.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Nov 17, 2004 - 4:34 AM
BGT4
Joined Jun 25, '04
cool. r u boosting at 17.5?
post Nov 17, 2004 - 9:53 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(BGT4 @ Nov 17, 2004 - 4:34 AM)
[right][snapback]208020[/snapback][/right]
Not yet......
About 16/17 I consider safe.
JDM ST205
post Nov 20, 2004 - 11:49 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
i would stay at 17psi if i were you.....just to be safe
it could handle more but it is hard to say what is safe from one person to the next.
DG
post Nov 21, 2004 - 3:02 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(Mr_E @ Nov 17, 2004 - 12:56 AM)
[right][snapback]207811[/snapback][/right]
mr E is right.
if you get an greedy prof. b spec. 2 you can see boost digitally.
stock boots is arround .9 bar fuel cut is arroud 1.25 bar. i am running about 1.15 bar. if you want to be safer remap your ecu for higher boost.
post Nov 21, 2004 - 3:52 AM
Slowrider
Joined Nov 16, '04
From Switzerland
ask GTN ist the popularst swiss japan tuner
Lo-Fi Version Time is now: February 24th, 2025 - 6:20 AM
