white smoke exuast, in the morning |
Nov 15, 2004 - 8:25 PM |
Enthusiast Joined Jun 26, '04 From Bay Area, California Currently Offline Reputation: 0 (0%) |
just wondering what it is and how i can fix it if its bad. I read about the blue smoke but is that different? Its kinda whiteish maybe blue not tooo sure b/c its not a lot of smoke also im kinda color blind so its hard. But yeah white smoke (possibly blue). Any thoughts? thanks guys
Nov 15, 2004 - 9:34 PM |
Enthusiast Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
well blue will be the oil.
-------------------- PROJECT 6TH GEN
<FS: Things up for grabs> <Progress> |
Nov 15, 2004 - 9:40 PM |
Enthusiast Joined Aug 22, '04 From kitchener,Ontario Currently Offline Reputation: 0 (0%) |
Does your car have a turbo?Because it could be your seals going.But either way it sounds like oil!
Nov 15, 2004 - 9:42 PM |
Enthusiast Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) |
how many miles does to have??? if its over 60k have you ever changed you head gasket ... i know my old 5sfe started doing that and it was the head gasket .... so ui jsut swaped the motor lmao
-DMC |
Nov 15, 2004 - 10:02 PM |
valve stem seals.
-------------------- Project ST204.5 99.88946% complete... |
Nov 16, 2004 - 12:04 AM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
white smoke is coolant burning. the valve stem seals would emit a blue smoke since there is oil on the seals.
This post has been edited by rjbibeau: Nov 16, 2004 - 12:04 AM -------------------- |
Nov 16, 2004 - 12:22 AM |
damn well it all sounds bad ill take a look tomorrow morning. I just had the 60k check up not to long ago and everything was fine... the car only has 57k on it or like 56789 somethin like that haha 5-6-7-8-9 funny didn't realize but yeah not too much and with the check up should b ok...
Nov 16, 2004 - 1:14 AM |
QUOTE(rjbibeau @ Nov 15, 2004 - 11:04 PM) white smoke is coolant burning. the valve stem seals would emit a blue smoke since there is oil on the seals. [right][snapback]207357[/snapback][/right] He DID say he was somewhat color blind and it's only a little bit of smoke from cold starts which has been determined that the most likely culprite is valve stem seals. Read Read Read This post has been edited by WannabeGT4: Nov 16, 2004 - 1:22 AM -------------------- Project ST204.5 99.88946% complete... |
Nov 16, 2004 - 1:17 AM |
Enthusiast Joined Jul 7, '04 From charlotte N.C. Currently Offline Reputation: 0 (0%) |
is it only in the mornings (when its cold i.e. around 30 - 40)or all times of the day like when its 70 outside.
-------------------- Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph. Next: maybe an elise |
Nov 16, 2004 - 1:31 AM |
nop SOLEY the mornings after that im clear as well..clear ok
Nov 17, 2004 - 2:10 PM |
Enthusiast Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
White smoke is rarely a problem, black and blue possibly. White smoke in only the mornings is usually moisture build up from the car sitting over night with the morning dew, much of the same that happens to your windows over night.
More likely then not, its nothing to worry about. |
Nov 17, 2004 - 3:05 PM |
You guys are scaring the sh!t outta him, my god.
Its most likely condensation, IE why its only in the mornings where EVERYONES car does this in the mornings. Did it do this in the summer? -------------------- |
Nov 17, 2004 - 3:25 PM |
Enthusiast Joined Nov 25, '03 From Pittsburgh, PA, USA Currently Offline Reputation: 0 (0%) |
if youve done some engine work, you might a crossed some lines coolant w/ vac etc... but i think it is also just cus its morning.
Nov 17, 2004 - 3:28 PM |
Enthusiast Joined Jul 14, '03 From Jacksonville, FL Currently Offline Reputation: 2 (100%) |
My car does this.. in the morning.. and during the day.. when it's hot.. or cold outside.
I was told I needed a new head gasket. -------------------- |
Nov 17, 2004 - 3:36 PM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
QUOTE(Jen @ Nov 17, 2004 - 8:28 PM) My car does this.. in the morning.. and during the day.. when it's hot.. or cold outside. I was told I needed a new head gasket. [right][snapback]208200[/snapback][/right] Sounds like you do. You can do a compression test and see if 1 or 2 are below normal, and you can also check your oil next time you change it. If it is milky, then your leaking coolant, most likely a blown head gasket. If the coolant gets mixed in with the oil... well you can imagine what it can do to your internals. When you do get it replaced, make sure you know why it blew in the first place, and address it so it doesnt happen again. Many times if your engine overheats, the head will warp, and cause the gasket to blow. So if you replace the gasket, take the head to a machine shop and make sure it is totally flat. -------------------- |
Nov 17, 2004 - 3:45 PM |
it doesn't mean that he can have someone else tell him what color smoke it is.
Nov 17, 2004 - 3:55 PM |
A blown head gasket would be alot more noticeable than some smoke.
Nov 17, 2004 - 8:01 PM |
Enthusiast Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
Condensation... period
Nov 17, 2004 - 9:12 PM |
Enthusiast Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
Yeah I don't think it is any thing to worry about about. My car does it in the morning and I see it coming from all the other cars too.
-------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Nov 17, 2004 - 9:29 PM |
well checked this morning, maybe it was a little warmer out or somethin but no smoke and yes its only in the mornings and yes my car sits outside all night and no it didn't do it in the summer and for the questions ur gonna ask the answers are yes yes no yes no no no yes yes and you will only live to age 67 and will have 3 kids and wait, srry times up. =D but i think im ok guys.
Lo-Fi Version | Time is now: November 28th, 2024 - 2:06 AM |
