> does the 4agze head bolt to the 7afe
post Nov 15, 2004 - 11:21 PM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
does the 4agze head bolt to the 7afe without any modifications, i am going to make a 7agte engine and i am going to use the 7a block, 4agze head, 4agze pistons,and Garrett T3 turbo, i want to make about 250-300HP which i think is possible with this hybrid, will the head bolt up right? can i still use the 7afe ECU or do i have to get the gze ECU, thanks alot
-Jeremy
post Nov 16, 2004 - 12:19 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Irishflame27 @ Nov 16, 2004 - 4:21 AM)
-Jeremy
[right][snapback]207324[/snapback][/right]
The head will more or less bolt up. Gotta use a 4AG head gasket. Gotta use 4AGZ ECU, sensors, and possibly plugs/wiring. Gotta get some sort of intake manifold (bigport dula runner or smallport single runner). All depends on how you approach it.
post Nov 16, 2004 - 12:30 AM
FallenHero
Joined Dec 26, '02
From Alabama
I could tell you what I think, but I don't know if you want to hear it.
post Nov 16, 2004 - 10:50 AM
nik
Joined Sep 30, '02
i've read alot on this subject like the 300 hp mr2 with 20v head on 7afe block
http://www.corollaperformance.com/Mods/Eng...GE.html#rayhall
i think you might want to ask Frotou (spelled wrong) but if you do the 7agze into the 7agte get a map base head.
post Nov 16, 2004 - 6:56 PM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
thanks alot guys
Lo-Fi Version Time is now: December 4th, 2024 - 3:08 PM
