> FS: Audio Equipment, Kicker Subs, Audiobahn Amp + more
post Nov 16, 2004 - 3:13 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
I am trying to sell everything together, and preferrably local pick-up.
notice i said preferrably.
Reason of sale: My spoiler was stolen so i am need of money to fix the hatch, and buy tires for winter.
2 Kicker Solor Baric S8L7.
-These are the new model(Silver Cone, blue writing)
-Used only since July
-Never used in competition
-Dual 4 Ohm
-Peak Power 900Watts
-RMS Power 450Watts
-Sensitivity 84.5
-Freq. Response 28-100
-.33 Minimum enclosed size(sealed)
1 Audiobahn A8002T Amplifier
-200 watts RMS x 2 at 4 ohms
-400 watts RMS x 2 at 2 ohms
-800 watts RMS x 1 at 4 ohms
-stereo or bridged mono output
-Tri-way capable (Tri-Way Crossover required)
-MOSFET power supply
-high gloss chrome plate finish with blue illumination
-variable crossovers (50-750 Hz, 18 dB/octave high-pass, and 50-120 Hz, 18 dB/octave low-pass)
-subsonic filter (20-50 Hz)
-18 dB bass boost (switchable on/off)
-preamp outputs
-preamp- and speaker-level inputs
-cooling fan
1 Streetwires PS04BSi
-18 feet of 4-gauge blue power cable with attached ring terminal
-waterproof, in-line, solid-brass fuse holder (with diamond-plate nickel finish) installed on power cable with 80-amp AGU fuse
-5 feet of 4-gauge silver grounding cable
-one 16.4-foot RCA patch cable (clear jacket, silver conductors, with molded black connectors) with built-in remote turn-on wire
-assorted connectors and spade terminals
-6 plastic wire ties
1 Dual Ported Custom Made Box
-made for "street bass" at max recommended size.
Pictures can be seen here:
http://photobucket.com/albums/v153/ConSynX/For%20Sale/
Through Cruthfield the Subs, Amp, and Wiring kit alone sell for over $800
with this custom Dual Ported box I am hoping to get around $600.
Offers are accepted.
post Nov 16, 2004 - 11:53 PM
Consynx
Joined Dec 25, '02
bump
post Nov 25, 2004 - 5:35 PM
Consynx
Joined Dec 25, '02
bump
post Nov 28, 2004 - 4:11 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
Hey will you sell things seperately? how long has the amp been used and some pics? thanks
Dustin
post Nov 28, 2004 - 7:55 PM
Consynx
Joined Dec 25, '02
pics are at that link.
I am not parting out, sorry
post Nov 29, 2004 - 12:40 PM
Consynx
Joined Dec 25, '02
bump
post Mar 3, 2005 - 10:35 PM
Consynx
Joined Dec 25, '02
figured one last bump for GL, although it's prob bad luck
post Mar 11, 2005 - 2:22 AM
Consynx
Joined Dec 25, '02
just grouping it all...
buyer hasn't exactly fallen through, but contact has been lost
post Mar 25, 2005 - 2:34 AM
PolishCeli
Joined Nov 18, '04
From DETROIT, MICHIGAN
if ur willing to part how much would u want for one of those subs
Lo-Fi Version Time is now: February 20th, 2025 - 5:55 AM
