> Info For 7AFTE guys :), B16 pistons may fit !!!!!!!
post Nov 18, 2004 - 5:03 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
After then Fallenhero posted topic about Civic pistons i'v made a few researches smile.gif
Basicly piston diameter (bore) of b16 and 7A are the same (81 mm stock)
Wrist Pin diameter is a bit different 7A is 20 mm and B16 is 21 mm
but this is not a problem smile.gif The only thing that need to be cleared out is 7A piston height and b16 pistons heigh...
this way we guys will be able to use forged pistons from B16, and tehy are cheaper then toyota pistons smile.gif)
<<<<<< DCw / JDMart >>>>>>>
post Nov 18, 2004 - 10:23 AM
nik
Joined Sep 30, '02
i'll ask the performance shop near me they should have some pistons on hand
post Nov 18, 2004 - 10:47 AM
FallenHero
Joined Dec 26, '02
From Alabama
ok, from what I have seen the regular honda pistons are Hella domed. However, the Low comp honda pistons are almost flat like 7a units, and should work pretty well. Hey doggy, did you see any info on using honda rods? That is, after all, one of the major 7a weaknesses. What is the crank diameter on a 7a? Any clue?
post Nov 18, 2004 - 12:13 PM
nik
Joined Sep 30, '02
towards the end of this post guys were talking about the 2zz rods, pistons, etc MIGHT fit no hard facts yet. http://www.6gc.net/forums/index.php?showtopic=11094&st=40
but buy the b16 low comp coated pistons with 2zz rods i wounder if it would work.
post Nov 18, 2004 - 1:45 PM
Fox-N-It2
Joined Jul 24, '04
From Va
QUOTE(nik @ Nov 18, 2004 - 5:13 PM)
[right][snapback]208547[/snapback][/right]
B16 low compression pistons are low compression for hondas but due to head differences they might not be so low for toyotas. Any idea on the combustion chamber size difference between b16 and 7a?
This post has been edited by Fox-N-It2: Nov 18, 2004 - 1:50 PM
post Nov 18, 2004 - 11:45 PM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(Fox-N-It2 @ Nov 18, 2004 - 11:45 AM)
[right][snapback]208577[/snapback][/right]
yea, that's the point. smile.gif You see, the stock pistons on the B16 are DOMED like huge. Thy literally have a /\ looking piston. The low comp ones should be more around the compression we would need for a higher reving NA engine. I just don't have the numbers to check on it.
post Nov 19, 2004 - 8:59 AM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
i am really interested to see if these would work, that would be awesome if they do!
post Nov 19, 2004 - 1:07 PM
Nemises
Joined May 6, '04
From antioch CA
Thats funny so the heart of your toyota engine is a honda. isint that like jungle feaver lol. Good find though im interested to see if they work even though im almost positive im going to swap.
post Nov 19, 2004 - 2:56 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Honda B series low-comp pistons probably won't lower compression in the 7AFE. Just consider 4AGZ pistons are the low-comp counterparts to 4AGE pistons, which are not domed... even if the B16 lowcomp pistons are flat... they still may not lower compression. Even so... it'll make a good n/a piston... but so will a 4AGE piston... with less hassle. Good price + machining work is probably gonna be more than 4AG pistons. 4AG pistons only run a bit more than B16 pistons. Also... if you plan on machining the piston... better get forged pistons. Cast pistons tends to crack and stress...
Doggy... 2ZZGE pistons have been fitted in a 7A block (7AGE hybrid)... The rods on the other hand... are still in question...
post Nov 19, 2004 - 3:07 PM
Skate4mindgame
Joined Oct 1, '04
From Michigan
May be off topic but i was looking at these for a 7agte i was planning on starting but im not sure what the compression would be the same as its listed ... or if they would even fit.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
Lo-Fi Version Time is now: November 24th, 2024 - 1:27 AM
