Enthusiast ![]() ![]() Joined Sep 23, '04 From fresno Currently Offline Reputation: 0 (0%) ![]() |
WHAT IS A GOOD SIZE TURBO WITH QUICK RESPOUND ?? ON A 7AFE...AND HOW MUCH COULD STOCK 7AFE WITH A TURBO KIT ON IT STAND WITH BOOST?
Enthusiast ![]() ![]() Joined Aug 22, '04 From kitchener,Ontario Currently Offline Reputation: 0 (0%) ![]() |
The ct26 is the perfect turbo and you can easily run 8psi.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
If the ct26 works good on the 7afe, why do most people get t3/t4? Am I misunderstanding something?
i wounder y too??
Because most of the people doing it dont know any better!They get a good turbo but you cant use it to its full potential.A ct26 or a ct20b will be more than enough to make you s--t your pants.Just remmember that every psi of boost is 10 hp so if you are running 8 pounds of boost your at 210 hp safely!Dont just think of power think of making your car efficiant.Efficiancy will make your car faster.Example 15 psi boost depending on the turbo and the engine it might have lots of lag,Where your boost will start in lower rpm.More power out of the whole.But if you want a big turbo it takes time to spool up depending on the turbo!
really??? Does anyone make a exhaust maifold or header that bolts onto the A series that fits a CT26 turbo?
![]() Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) ![]() |
t3
Enthusiast ![]() Joined Nov 24, '02 Currently Offline Reputation: 0 (0%) ![]() |
Didnt you just say in another post you bought a 3sgte? Just curious. I might of missed something.
yup i just got a 3sgte..but since the other 7afe motor is just sitting around..........now..just wanna play around with the motor since its out...whenever its need to b put back in when 3sgte is in trouble..thanks thoug
Lo-Fi Version | Time is now: February 24th, 2025 - 12:19 PM |
