E Brake light coming on., General Advise |
Nov 22, 2004 - 1:50 PM |
Enthusiast Joined Oct 21, '02 From Oakland, Ca Currently Offline Reputation: 0 (0%) |
I have recently been encountering a problem with my e-brake light. It comes on when I brake or when I accelerate and shift gears. It does this a lot in the morning and seems to go away as the car warms up. Any ideas what this could be? I drive a 1994 ST. Thanks.
-A |
Nov 22, 2004 - 2:07 PM |
You probably have a short - check ur wiring.
Nov 22, 2004 - 2:21 PM |
check your brake fluid. If it is low, the brake light will come on.
Nov 22, 2004 - 2:27 PM |
QUOTE(Supersprynt @ Nov 22, 2004 - 12:07 PM) You probably have a short - check ur wiring. [right][snapback]210370[/snapback][/right] OK, Thanks. |
QUOTE(Batman722 @ Nov 22, 2004 - 12:21 PM) check your brake fluid. If it is low, the brake light will come on. [right][snapback]210382[/snapback][/right] I did check it and it is in the normal area. Thanks anyways. |
Nov 23, 2004 - 1:22 AM |
Enthusiast Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
QUOTE(asolorzano @ Nov 22, 2004 - 7:27 PM) QUOTE(Batman722 @ Nov 22, 2004 - 12:21 PM) check your brake fluid. If it is low, the brake light will come on. [right][snapback]210382[/snapback][/right] I did check it and it is in the normal area. Thanks anyways. [right][snapback]210388[/snapback][/right] i thought the same thing.... had the same problem.... bring the level to full.... it will stop that from flickin on |
Nov 23, 2004 - 2:43 AM |
Enthusiast Joined Oct 13, '03 From Dandridge, Tennessee Currently Offline Reputation: 0 (0%) |
Release your e-brake, haha. sorry I couldn't resist.
-Brandon -------------------- |
Nov 23, 2004 - 8:17 AM |
I didnt see the "E" i thought ur 3rd brake light was coming on when you did all that, a short it probably is not.
Nov 23, 2004 - 1:26 PM |
its low on fluid, mine did it too. its so low it washing over the sensor.
Nov 23, 2004 - 4:42 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
your fluid isn't low. Your pads or shoes are low. Do a brake job and it'll go away. The only way brake fluid gets low is if there is a leak, other then that brake fluid can't escape and it does burn up or deterioate. If you check your fluid and its low then it means you have a leak or your pads and shoes are low.
Nov 23, 2004 - 10:16 PM |
QUOTE(Junior @ Nov 23, 2004 - 9:42 PM) your fluid isn't low. Your pads or shoes are low. Do a brake job and it'll go away. The only way brake fluid gets low is if there is a leak, other then that brake fluid can't escape and it does burn up or deterioate. If you check your fluid and its low then it means you have a leak or your pads and shoes are low. [right][snapback]211095[/snapback][/right] not true i filled mine 2 months ago.... level hasnt changed.... my pads had over 50% left on them and it was flickering under certian conditions.... if the shoes/pads were low then it would only flick on when the pedal is pressed.... he says its on acceleration and braking.... which means fluid is sloshing due to centrifical force |
Nov 24, 2004 - 12:59 AM |
exactly, fluid moves when there is space. low pads creates more space in the brake lines.
Lo-Fi Version | Time is now: January 11th, 2025 - 3:00 PM |
