Vibration at 75 MPH |
Nov 22, 2004 - 2:08 PM |
Enthusiast Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) |
I recently have noticed a bad vibration felt through the steering wheel (back/forth movement through the steering wheel) at arounf 75 MPH. Under that speed everything feels just fine, but over its defintely present. The only thing I can think of that has changed is 2 weeks ago they rotated tires. Any ideas on the cause?
Nov 22, 2004 - 2:09 PM |
balance your tires.
Nov 22, 2004 - 3:59 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
do you have snow is your area if soo check the inside of the rim for ice chunks or snow that has built up. this will throw your tires off balance. it could also be mud chunks too.
Nov 24, 2004 - 6:31 PM |
Enthusiast Joined Aug 14, '04 Currently Offline Reputation: 0 (0%) |
Yeah, its porbly the tires I had the same exact problem a few weeks ago. I changed my tires and got them balanced, and everything was cool after that.
Nov 24, 2004 - 7:23 PM |
Enthusiast Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
get your tires balanced, might be a bent rim. My dads car did this too but once we put his stock rims back on it went away.
-------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Nov 24, 2004 - 8:54 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
when i put my wheels on the steering whell would shake. i then got some hub rings and put them on and that stopped the shaking. you should also check your wheels for balancing and for bent rims.
Nov 25, 2004 - 12:44 PM |
This is my guess after they rotated the tires the set on the front was not balanced, however I 'll know in the spring, I just put my winters on with 14" steelies, and things seem fine. I'll keep you guys updated.
Thanks exx |
Nov 25, 2004 - 3:09 PM |
simple problem... your wheels need to get balanced.... ..
Nov 26, 2004 - 3:42 AM |
finally a day without rain, drove around 80 mph without the vibration on my steelies which were balanced. When I switch back to my 16" wheels I'll get them balanced. Amazing how you only notice the vibration over 70MPH
Dec 23, 2004 - 1:35 PM |
Enthusiast Joined Dec 15, '04 From newcastle england Currently Offline Reputation: 0 (0%) |
my mate has a terd volvo and his did this,they tried the tyres and rims,but it is much worse,the axles or somthing,i'll get back when i ask him exactley what the prob is,have you had any work done to you g6 latley,garage might be responsible!
Dec 23, 2004 - 2:05 PM |
Enthusiast Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
Since this topic was resurected, I might as well ask:
I get a vibration in low gears between 0-30mph. What might it be? Anyone else have or did have this problem? -Ivan- |
Lo-Fi Version | Time is now: December 3rd, 2024 - 8:16 PM |
