Synthetic oil, which ones are good? |
Nov 23, 2004 - 5:30 PM |
Enthusiast Joined Nov 27, '03 Currently Offline Reputation: 0 (0%) |
I use Fully synthetic Amsoil 2000 series 75W90 trans oil in my manual... its expensive but man is it good.
Nov 24, 2004 - 2:42 AM |
Enthusiast Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
QUOTE(Junior @ Nov 23, 2004 - 9:48 PM) As far as tranny fluid, what do you have? Manual or auto? [right][snapback]211102[/snapback][/right] Manual... It seems that the majority (that replied) uses mobile 1. That was the one I was thinking of. -------------------- CLOSED on 25 acres! -shop coming soon.... |
Nov 24, 2004 - 5:26 AM |
Enthusiast Joined Jun 21, '03 From FRANKFORT,KENTUCKY Currently Offline Reputation: 0 (0%) |
I switched to synthetic oil (Castrol gtx) at about 120,000 miles. It starts better in cold weather,runs smoother, seemed like a tiny tiny tiny bit more power( i could be wrong). I wish I hadn't switched though because now it leaks oil really bad,a quart and a half in a 5 day work week, and it cost alot to keep oil in it. Synthetic oil isn't bad, but switching to synthetic at a higher mileage will show you problems that you would have otherwise not seen,like worn gaskets. When I get a brand new car I will put in synthetic but not in another used car or motor. Besides an engine gets accustomed to the type and grade of oil it gets on a regular basis
Nov 26, 2004 - 10:31 PM |
Enthusiast Joined Dec 13, '03 From Alabama Currently Offline Reputation: 1 (100%) |
When I put synthetic oil in my trans almost all of it leaked out. But, when I switched back to regular of the same grade it stopped.
Nov 27, 2004 - 3:05 AM |
Enthusiast Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) |
Nycelica I think you have it backwards, shouldn't you use the thinner oil 5W10 in the winter, and the 10W40 in the spring summer. Its cold, so you would want a thinner oil?
In regards to 95SThatch, dude a 2 quarts in a 10 working days. That is absolutely terrible. Any gain you get by using systhetic is probably lost with all the cost of putting oil in to the vehicle. I'd switch to 10W30 maybe Quakre state max life, or valvoline high mileage. |
Dec 2, 2004 - 4:22 PM |
Enthusiast Joined Oct 25, '04 From Los Angeles Currently Offline Reputation: 0 (0%) |
Im using Castrol 10W30, its great stuff, but as mentioned it tends to leak and also early morning shifting can be hard, Im think of going back to petroleum base. Yes it is possible!
Dec 3, 2004 - 2:06 AM |
Enthusiast Joined Aug 17, '03 From Bangkok, Thailand. Currently Offline Reputation: 0 (0%) |
I'm using Top Secret engine oil....
Not bad... The engine runs very quite and gives smooth acceleration all the way to the Red Line. Easy "in the morning" start-up as well. |
Dec 3, 2004 - 2:32 AM |
I know I don't have very many boxes, which means I haven't had many posts, which means poeple don't take me serious very often. But please, everyone out there who swiches to synthetic oil after using regular, your first change should be within a 1000, closer to 500. And the next should be under 2000, closer to 1000. Synthetic is thinner, as most people know, but it will break lose stuff that the original oil left in there. These things that were gummed up in the corners of the engine will break lose and could find there way to something important. So if your going to swich, and I recomend swiching, do this. I use Castrol full synthetic with K&N filter. Works great, you'd be hard pressed convincing me to change.
Dec 4, 2004 - 3:37 AM |
I just wanted this post to get back up to the top to make sure people had a chance to read what I said in my last post before switching oils. This is every important and yet often neglected.
Lo-Fi Version | Time is now: November 27th, 2024 - 11:17 PM |
