> Fuel Cut/Loss of power @ 0 lbs.
post Nov 23, 2004 - 11:50 AM
erics1one
Joined Aug 27, '04
From Orange County, CA
My VAC is between -19 & -21 at idle, but when I try to boost and it reaches 0 lbs, I lose power. My RPMs are normally around 2500-3000 when this happens. If I punch it (which I hardly ever do) I can get it above 0 lbs and boost fine.
The turbo has no shaft play, and was installed a couple of weeks ago. I'll be bringing it down to the shop today, but wanted to see if anyone here knew what it might be.
Thanks.
post Nov 23, 2004 - 12:07 PM
my guess would be boost leak, or exhaust manifold leak. do you have a fmic, or topmount?
post Nov 23, 2004 - 12:12 PM
nik
Joined Sep 30, '02
how do you have mbc hooked up?
post Nov 23, 2004 - 12:44 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
alomost the same prob i had ... cap off the VAC line between the wastegate actuator and the TVSV
post Nov 23, 2004 - 12:52 PM
I dont think he has a 3sgte - atleast his profile doesnt say so.
post Nov 23, 2004 - 1:24 PM
erics1one
Joined Aug 27, '04
I have the 5SFTE
The right side VAC line on the wastegate actuator is capped.
I have a front mounted Spearco Intercooler.
Thought that it was a manifold leak as well, checked this morning, everything is tight. I used the correct torque setting when installing the new turbo.
I'll get some pictures of my VAC line setup when I get home.
This post has been edited by erics1one: Nov 23, 2004 - 1:25 PM
post Nov 24, 2004 - 11:03 PM
erics1one
Joined Aug 27, '04
Not all vacuum lines were zipped tied.
Zipped 'em all up, reset the ECU, problem went away. Must have been a loose line.
post Nov 25, 2004 - 12:47 AM
yeah, loose vac lines= boost leak. i noticed that the metal hose clamps you can get at pepboys work a lot better then zipties, so you might want to look into those if your ties fail.
what type of vac readings to 5sfTes get at idle anyway?
post Nov 25, 2004 - 11:35 AM
erics1one
Joined Aug 27, '04
It usually sits between -19 to -21.
I still get a lot of resistance/hesitation below ~2700 rpms untill the boost kicks in. Pretty sure thats typically normal with this kit, but am interested to see how much a dyno tune will correct which I plan on doing soon.
Lo-Fi Version Time is now: January 11th, 2025 - 5:03 PM
