> is this normal shifting?
post Nov 25, 2004 - 11:06 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
in my auto st, the redline is ~ 5900rpm. when the engine temp is normal, it shifts at about 5700rpm at wot. is this normal?
post Nov 26, 2004 - 3:53 AM
Newbie
Joined Nov 3, '04
From Colorado
Yup. Automatic transmissions rarely ever shift at redline stock. Unless you broke your TCM or something, or modified it..
Edit: Forgot to post this.. Don't feel bad.. Some cars are made to shift 1k rpm before the redline.. Like my parents minivan.
This post has been edited by Newbie: Nov 26, 2004 - 3:54 AM
post Nov 26, 2004 - 9:35 PM
Anub1s
Joined Nov 27, '03
5800 is actually a good place to shift for our cars. You really don't need to go past that unless you are turbo or have some hefty mods. You may be losing out a little bit on your 5700 but not a whole lot. If I were you I would do a manual swap.
This post has been edited by Anub1s: Nov 26, 2004 - 9:36 PM
post Nov 27, 2004 - 3:09 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
I've noticed this too on other cars i've had, I wonder if at wide open throttle that the injectors are able to spit the gas out quick enough to build power. Like there is too much air coming in for the amount of gas it's able to put out. I don't know,just a thought.
Lo-Fi Version Time is now: February 20th, 2025 - 12:15 AM
