5 Pages V  < 1 2 3 4 > »
> Español para dudas, Desde españa
post Nov 28, 2004 - 5:04 PM
LatinKraze
Joined Oct 22, '03
He wants to lower tha car and get spacers for the rims so they are flush with the body of the celi. But he does not want to risk rubbing.
No se si tienen seradores traseros. Pero lla les pregunte a los que saben mas de suspencion que yo. Pero para bajar el coche y darle una mirada deportiva entonses lo mejor que puedes hacer es comprar unos springs de Eibach. Te bajarian una pulgada y media. Con esto no corres peligro de rosar. Pero lo mas simple que puedes hacer para ampliar el ancho de las vias seria comprar unos rines anchos. La medida ideal seria 17 pulgadas y de 7 a 7.5 pulgadas de anchas. Hojala y esto te allude. Has nos saber si necesitas mas informacion.
-Ivan-
This post has been edited by LatinKraze: Nov 28, 2004 - 7:15 PM
post Nov 28, 2004 - 6:55 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
Are you sure he doesn't wanna put it on hydraulics and give it 13 inch wire rims?
- Ryan
aim: rkgreen04
post Nov 28, 2004 - 6:56 PM
vangSTa_celica
Joined Jul 10, '03
From Appleton,WI
That was stupid and stereotypical man...
A Jaws4God Creation...
post Nov 28, 2004 - 6:57 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
It's cool. I'm Mexican. We do it all the time.
- Ryan
aim: rkgreen04
post Nov 28, 2004 - 7:13 PM
LatinKraze
Joined Oct 22, '03
QUOTE(Akimbo @ Nov 28, 2004 - 3:57 PM)
[right][snapback]213503[/snapback][/right]
Lol, it's true. I make stereotypical comments myself.
EDIT: Nothing too harsh though.
This post has been edited by LatinKraze: Nov 28, 2004 - 7:13 PM
post Nov 28, 2004 - 7:15 PM
ghostdog
From ny to philly
this thead is awesome because I took 7 years of spanish and barely have any idea whats going on biggrin.gif
post Nov 28, 2004 - 7:17 PM
LatinKraze
Joined Oct 22, '03
Dont worry, i took spanish back in high school and passed with a "D"...and my first language was spanish. How sad.
post Nov 28, 2004 - 7:25 PM
batmanjavi
Joined Jul 24, '03
From España
Gracias Ivan, preguntaré por los Eibach... tenía pensado preguntar tambien por los TRD, y mis llantas son de 7,5 , son unas LENSO VPD. Pero como ya sabes el celica en la parte trasera es bastante ancho y la llanta no llega al borde del guardabarros. Aún así muchas gracias compañero. biggrin.gif
post Nov 28, 2004 - 7:53 PM
Jonathan
Joined Sep 21, '02
From Montgomery county/Rockville,MD
no te precupas...Ellos son estupidos
post Nov 28, 2004 - 8:17 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
Well, I have no clue how to answer him except this:
Go with a 18" x 7.5" rim. Go with a 38 offset. Go with the Eibach sportlines. That'll drop you down nice and give you big rims. Done.
And for my spanish translation via a translator site (this should be funny):
Bien, yo no tengo indicio para cómo contestarlo menos esto:
Vaya con una 18" X 7,5" borde. Vaya con una 38 desviación. Vaya con el sportlines de Eibach. Eso dejará le caer hacia abajo agradable y le da bordes grandes. Hecho. Espere que esto ayude un poco.
-Ti
This post has been edited by turboinduction: Nov 28, 2004 - 8:22 PM
post Nov 28, 2004 - 8:28 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
tell him instead of a spacer, to get a new set of wheels w/ a dif offset...
then BAM, no spacer needed.
No necesite unos spacers(seradores?). Todo el mundo recibiendo los...(wheels)llores?...nuevos. Hay los spacers(seradores) para Celica pero ellos para "Camry".
post Nov 29, 2004 - 12:24 PM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(Consynx @ Nov 28, 2004 - 6:28 PM)
[right][snapback]213554[/snapback][/right]
Agreed. I think I have a 45 offset and my rims are hella flush with the flares.
post Nov 29, 2004 - 1:42 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
tell him for lowering use a adjustable coilover system... if he has the rims already and doesnt want to get new ones use spacers off ebay... if he is close to tuckin rim the roll the fenders... any body shop can do this...
-DMC
post Nov 29, 2004 - 2:44 PM
LatinKraze
Joined Oct 22, '03
QUOTE(batmanjavi @ Nov 28, 2004 - 4:25 PM)
[right][snapback]213516[/snapback][/right]
Lo que me hacaban de decir es que si compras rines con una compensasion de 38 millimetros para las vias traseras, te quedarian all borde del guarda barros. Para eso tendrias que comprar dos rines differentes para el trasero. Muchas companias te podrian alludar con eso. Puedes darle una llamada a essas companias y lo mas seguro es que te dirian lo mismo.
This post has been edited by LatinKraze: Nov 29, 2004 - 3:05 PM
post Nov 29, 2004 - 2:48 PM
LatinKraze
Joined Oct 22, '03
QUOTE(thedevilmaycrie @ Nov 29, 2004 - 10:42 AM)
-DMC
[right][snapback]213981[/snapback][/right]
It's too much for me to explain, i dont know the proper terminology and might get the poor guy confused. I told him to call the company that hes buying rims from to see if they have the 38mm offset for his rear.
post Nov 29, 2004 - 2:54 PM
turboinduction
Joined Feb 25, '04
From Wisconsin
do you all understand offset? the higher the number, the more "in" the rims will be. 35 is flush, 38 is great, 45 is tucked in. So if this guy wants flush, i wouldn't be suggesting 45 for an offset.
post Nov 29, 2004 - 2:59 PM
Ricky
Joined Jul 28, '04
From Miramar Florida
Batmanjavi,
Puedes utilizar distintas maneras para bajar el auto. Eibach es una buena compañia de suspencion pero es un poco costosa. Exixten otras como Drop Zone que venden la suspension por una cantidad moderada.
No te preocupes por el rozar de las llantas en el auto. No necesitas "spacers" o seradores. Cunado compres los aros (wheels-rims) asegurate que no pasen de 8 pulgadas en la parte trasera. Si los compras de con mas de 8 pulgadas te van a rozar. Espero que esa informacion the ayude. Si necesitas algo me puedes preguntar.
Yo le puse aros 19X8 a mi Celica y luce muy bien.
post Nov 29, 2004 - 3:02 PM
LatinKraze
Joined Oct 22, '03
QUOTE(turboinduction @ Nov 29, 2004 - 11:54 AM)
[right][snapback]214008[/snapback][/right]
Dont shoot the messenger! I'll edit my post and leave it at 38 offset.
post Nov 29, 2004 - 3:32 PM
celicaspeed
Joined Aug 22, '04
From kitchener,Ontario
Im portugese and I can understand everything that hes saying but cant right back!
post Nov 29, 2004 - 3:51 PM
RedSunCelica
From San Diego CA
QUOTE(batmanjavi @ Nov 28, 2004 - 5:25 PM)
los eibach son mautivaudores buenos. tampien los de TRD y Tien. Pero no uses DropZone Coilovers muchos de aqui te van a dicier que no sone muy buens hechos.
se quieres que la lanta este con el guarda fango y que no toce pueres hacer lo que latin kraze acabe de decir de usar un rin de 38 millimetros .
Lo-Fi Version Time is now: December 2nd, 2024 - 11:16 PM
