Installing Underdrive Pulley, how do u get the actual pulley off?? |
Mar 20, 2003 - 12:39 AM |
Enthusiast Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
Ok, raised the car, took the bolts i needed off, took the belts off too, but how do i get the old pulley off?? everytime i twist the bolt in the middle, the whole pulley turns. stepping on the brake while in gear does not work, either. how do i get the s.o.b. off??
Mar 20, 2003 - 7:04 AM |
Enthusiast Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
Hit it with a hammer!
Nah j/k, i'll tell ya tomorrow after i look in my chiltons manual. But right now it's like 5.15am and raining outside, so fuk the thought of goin out right now and gettin it! |
Mar 21, 2003 - 5:13 PM |
Enthusiast Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
Did you get the pulley on Forkee? Im interested in the gains you got..
Mar 21, 2003 - 10:16 PM |
Enthusiast Joined Oct 14, '02 From Long Beach, CA Currently Offline Reputation: 0 (0%) |
The pully removal requires the use of an SST (Special Service Tool.) It cost about $150 from Toyota, but we actually spent for hours and made our own. Its kind of like a lever that you bolt onto the crankshaft pulley. You may notice if you;ve looked at your crankshaft pulley there are holes in it. That is where 6mm bolts screw in. Then while you hold the pulley still by the handle of the tool you can take the bolt off with a breaker bar. I have a pic of it below.
Joe |
Mar 21, 2003 - 10:52 PM |
Enthusiast Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) |
go rent a pulley puller from autozone. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Lo-Fi Version | Time is now: November 28th, 2024 - 2:49 AM |
