> ok i need some help installing my new window
post Nov 29, 2004 - 1:28 PM
celicarocker
Joined Sep 25, '03
From cranston RI
well thanks to some dickhead, i need to put in a new window... so im going to pick one up at a junkyard for $40 as soon as they call me back.... i started talking apart my door so when they call me i can just pick it up and put it in... i got off the door panel no problem, but theres still a big piece i need to take off...
so does anyone know how to get that metal piece off so i can get at the window? any help would be greatly apprecieated....
This post has been edited by celicarocker: Nov 29, 2004 - 1:29 PM
post Nov 29, 2004 - 2:07 PM
CelicaQT
Joined Sep 29, '02
From Sterling Heights, Michigan
Don't know if this will apply to installing the glass on a celi. But when I'm at the Build Center here at GM, the door glass is installed thru the opening between the outer door and the inner sheet metal. You wouldn't take any of the sheet metal you're displaying off. You tilt the front of the glass into that "space/crack", and guide it into place.
You have to tweek and manuver the glass into the glass run channel (that's what that obj. is on the right), once it's aligned in the run channel, move the rear edge into place also, then slide it into place.
I'll post a pic, I had to do a summary of when my glass was installed into the Cadillac Escalade.
post Nov 29, 2004 - 2:13 PM
CelicaQT
Joined Sep 29, '02
Here ya go, it's not exact, but it's a start.
post Nov 29, 2004 - 2:41 PM
celicarocker
Joined Sep 25, '03
From cranston RI
thanks ill have try that out whenever these people ever call me back saying i can come pick it up...
post Nov 29, 2004 - 4:56 PM
slipgun
Joined Jun 2, '03
From Annandale VA
AIM me if you have problems. I replaced the window regulator recently and am pretty familliar.
post Dec 4, 2004 - 11:30 AM
gas65
Joined Nov 6, '03
From Campbellsville, Ky.
Roll the window about half way down and you can see the bolts that hold the window in place(one of the bolts will be seen through that round hole beside the bright yellow screw holder in your picture), take those out and remove the old window frame and put your new window down into it. Just make sure you have both sides of the window in the tracks that keep it lined up.
post Dec 4, 2004 - 5:52 PM
celicarocker
Joined Sep 25, '03
From cranston RI
thanks for the responses guys....
gas.. much appriecieated but a little late, i already got it in =) but thats exactly how its done...
post Dec 4, 2004 - 10:34 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Yeah.... now imagine your window regulator was broken and the window was stuck halfway between seeing the bolts in the middle and seeing them at the bottom so you had to losen as much as you could one one and then cut the old assembly out... Note to everyone, NEVER let your window get stuck 3/4 down
Lo-Fi Version Time is now: February 23rd, 2025 - 2:31 PM
