> This is the Shopping List for the New Year, Suggestions or comments guys
post Dec 2, 2004 - 4:33 AM
Magic
Joined Mar 30, '03
From Cyprus
Guys if you are using any of the following parts or it happents to you to know anything that maybe will help please let me know.
Here is the list.
Greddy TD06 20G 8cm
Sard 255lph In-tank Fuel Pump
Power Fc by AP Engineering
Greddy VSPL Intercooler kit for Evolution with Custom Piping
Tuning by Mr.Koyama
I am also thinking for going with custom exhaust manifold.
Any tips will help.
Cheers
post Dec 3, 2004 - 2:40 AM
Lar-
Joined Aug 17, '03
From Bangkok, Thailand.
post Dec 3, 2004 - 3:21 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
....external Wastegate.... you mean biggrin.gif ?
QUOTE(Lar- @ Dec 3, 2004 - 12:40 AM)
[right][snapback]216166[/snapback][/right]
<<<<<< DCw / JDMart >>>>>>>
post Dec 3, 2004 - 3:23 AM
Magic
Joined Mar 30, '03
From Cyprus
Ehmmm...can i add the wastegate later my friend??? tongue.gif I have to re-make my exhaust manifold...hmmmmm.....
post Dec 3, 2004 - 3:37 AM
mmorg3053
Joined Mar 29, '04
From Manchester, England
Register at www.nengun.com and get the Power FC and commander especially for the ST205. Mine was GB £550 all in delivered. They accept Paypal and their paypal address is nengun@yahoo.com. Unless you can get it cheaper elsewhere of course.
post Dec 3, 2004 - 3:44 AM
Lar-
Joined Aug 17, '03
QUOTE(doGGy @ Dec 3, 2004 - 8:21 AM)
[right][snapback]216176[/snapback][/right]
Yapp.. An External Wastegate...
post Dec 3, 2004 - 4:03 AM
Lar-
Joined Aug 17, '03
QUOTE(Magic @ Dec 3, 2004 - 8:23 AM)
[right][snapback]216177[/snapback][/right]
Greddy and HKS make good External Wastegates as well....
... Sorry my friend... You can't add the wastegate later.
The TD06-20G doesn't have an internal wastegate(flapper) inside the turbine housing like our ct20b, so you have to get one external wastegate for the TD06-20G as well.. . biggrin.gif biggrin.gif
This post has been edited by Lar-: Dec 3, 2004 - 4:04 AM
post Dec 3, 2004 - 4:29 AM
Magic
Joined Mar 30, '03
From Cyprus
mmorg3053 I will check the website and let you know.About the Power FC I found the same one like Lar- is using by AP Engineering P/N: 4E14T02Z at 420CYP..i think its a good price.
Lar- Exhaust manifoldfor 3SGTE engines are very expensive!!!really!!!
Well i have to decide if i will go with custom or get one ready.I have to check also the prices for wastegate...hmmmm.....
post Dec 3, 2004 - 2:59 PM
jgreening
Joined Jan 17, '04
From Illinois
Magic: According to the Mr2 guys, the exhaust manifold for the 3sgte will support 400+ hp and is not subject to the same cracking risk of a tubular exhaust manifold. You may want to put money toward other mods such as an intake manifold or fuel upgrades.
- Jay
This post has been edited by jgreening: Dec 3, 2004 - 3:00 PM
post Dec 3, 2004 - 4:17 PM
boosted_K2
Joined Aug 30, '02
From Michigan
agreed with jgreening and -lar, you cant just add a wastegate later if it is not internally gated, if it is an externally gated turbo, then you need an aftermarket wastegate. you will also need an adapter plate to attach the external gate to the factory manifold, or you have to get a new custom manifold incorperating an external gate.
No but I don't buy it
Cause I'm...
post Dec 3, 2004 - 4:21 PM
Magic
Joined Mar 30, '03
From Cyprus
jgreening you suggest that i should stay with the stock 3SGTE manifold?Cuz i didnt get it.About fuel upgrades i am also thinking about injectors but for the bhp i need(360bhp) the stock injectors(540cc) are enought.
Yes boosted_K2 all of you are right on this,if the turbo does not internally controlled i should go with a wastegate from the start.
post Dec 3, 2004 - 6:03 PM
jgreening
Joined Jan 17, '04
From Illinois
Magic:
Correct. You do not need to replace the exhaust manifold at those horsepower levels - unless you are doing it for looks. The stock EM will not reach its limits and a tubular EM will not be much more efficient - no matter the design (and it could be worse). The longevity factor alone would persuade me to keep the stock EM.
As for the injectors, I have read that 550's are good for upto about 325whp at 85% duty cycle. Maybe Tim can confirm this.
Finally, the people who know 3s engines would never get a internally gated turbo upgrade unless very modest boost was planned. The internal gates simply cannot allow enough exhuast gas to escape fast enough causing dangerous boost creep.
Jay.
post Dec 3, 2004 - 6:15 PM
Magic
Joined Mar 30, '03
From Cyprus
Jay,a good idea its to try with the stock setup and if something seems to be weak then i should replace it.
For sure i am going to install the fuel pump,i am sure that i need it,and also the FMI....of course its always depends on "what bhp you want to reach".....
Thanks for the info dude
post Dec 3, 2004 - 11:04 PM
boosted_K2
Joined Aug 30, '02
From Michigan
is the 325 at 85% what wolfkatz concluded after his flowbench tests? MR Controls recommends to upgrade fuel pump and injectors at +275WHP, but its only worthwhile with proper fuel management, which quoting MRControls "a S-AFC does NOT qualify as proper fuel management, which im sure what they are getting at is a PowerFC or any type of EMS system to really optimize modifying the fuel system. you should probably put a FPR on at the same time as well.
Cause I'm...
post Dec 3, 2004 - 11:49 PM
jgreening
Joined Jan 17, '04
From Illinois
Tim:
Remember that Magic's car is a Gen III. He has 540's (not 440's) - the 275 whp max for gen IIs does not apply.
Jay.
This post has been edited by jgreening: Dec 3, 2004 - 11:51 PM
post Dec 4, 2004 - 2:59 AM
Magic
Joined Mar 30, '03
From Cyprus
boosted_K2 Yes a Sard FPR its on the list also (Cuz FPR its too cheap i forgat to mention it) biggrin.gif biggrin.gif
post Dec 4, 2004 - 11:16 AM
boosted_K2
Joined Aug 30, '02
From Michigan
this is true, i forgot about it being a gen 3, reguardless i still stick to what i said but yes, you should be in the clear with 540s for the power range you are looking for, but a new fuel pump and especially the FPR would be a good addition.
Cause I'm...
post Dec 4, 2004 - 11:29 AM
Magic
Joined Mar 30, '03
From Cyprus
Cheers for the info boosted_K2
post Dec 4, 2004 - 1:41 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
what does Power FC do?
because one of those on the 7th gen supposedly puts it in the 13's
post Dec 4, 2004 - 1:43 PM
Lar-
Joined Aug 17, '03
This is a good thread.... Everyone is adding in very useful infos... .
Lo-Fi Version Time is now: January 10th, 2025 - 7:50 AM
