> any way to make 17x7s look flush, without using spacers
post Dec 2, 2004 - 8:02 PM
is there any way that a normal 17x7 wheel will look flush with the body of the car? is there an offset that would do the trick, or do we need the right offset and wheel width ?
post Dec 3, 2004 - 2:21 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Some spacers should help out, if they don't enough, then you could put longer bolts in for the lug nuts. I don't recomend putting to much longer bolts on. You can go a good 1/2 inch safely. I'm going to put some 1/4's on my car.
Live Free, Be Happy
post Dec 3, 2004 - 10:26 AM
Simply putting on longer studs on won't do anything, unless you're using spacers.
But the best way to go about it would be to use some wheels with the correct offset(and you'd want staggered offsets to have the same flush look in both the front and rear.) I'm just not sure what exactly the offsets are. I remember a while back though there were some Sparco 16" rims on eBay with staggered offsets that were perfect for Celicas...some guy bought them for his fourth gen, so I'll see if I can track him down and get some info. smile.gif
post Dec 3, 2004 - 11:27 AM
but, would offset alone do the trick? i would imagnine that there is only so much ofset that we can have, before you cant put the lugs on safely.
post Dec 3, 2004 - 11:35 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
The lugs will go on fine with any offset. With spacers though you may need longer lug studs to be safe. Ya, the offset alone would do the trick...but so would spacers (which are way cheaper than new wheels)...but you would probably need longer bolts for the lug nuts to be safely tightened.
This post has been edited by bufferdan: Dec 3, 2004 - 11:37 AM
post Dec 3, 2004 - 1:02 PM
just need the right offset, it was somewhere around 32--35 if i rember correctly
post Dec 3, 2004 - 1:49 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(presure2 @ Dec 3, 2004 - 6:02 PM)
[right][snapback]216283[/snapback][/right]
That would just about do it. I'd go as far as saying something in the high 20's can fit snug in the rears... while the fronts might require 30's to clear stuff. The only way to do it correctly is to either change the wheels and wheel offset or get spacers.
post Dec 3, 2004 - 2:44 PM
are you guys sure that i can safely use a 30 offset on the car, or a high 20?
basically, i need new tires and im thinking of a different style of rim too. the original plan was to get 17x8s but they are alot harder to find and cost more then i want to spend on rims right now, so i was hoping that i could get away with a 17x7 if i found the right offset.
does anyone here have 17x7s on their car that look flush with the body, or at least not "pushed in". i always thought that you need 8in width and the right offset to do the trick.
This post has been edited by lagos: Dec 3, 2004 - 2:46 PM
post Dec 3, 2004 - 2:51 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(lagos @ Dec 3, 2004 - 7:44 PM)
[right][snapback]216340[/snapback][/right]
Yes... you can probably use lower offsets fine. On the rear, possibly even lower than the fronts. I believe 28 or so offset in the rear should be able to clear the rear calipers. That's the only worry on the rear. The wheel should easily clear the rear 1/4. As for the fronts, you gotta clear the fender, the wheel wells while turning, the calipers, etc... so I wouldn't go as low as high 20's in the fronts... but 30's should be fine. I believe the stock 15x7 wheels are 32 or 36 offset.
This post has been edited by Kwanza26: Dec 3, 2004 - 2:52 PM
post Dec 3, 2004 - 4:08 PM
post Dec 3, 2004 - 4:40 PM
id really love to hear from somone that has a low offset on their car. the way that i understand it, is the lower the offset, the less threading there is for the lugs. so there must be a limit, higher then something in the 20s. i could see 35, but im skeptical about a 20 offset that Kwanza26 recomends.
post Dec 3, 2004 - 4:53 PM
Nah, offset won't affect how many threads your lug nuts catch on...offset isn't the width of the mounting surface of the wheel. wink.gif
post Dec 3, 2004 - 5:13 PM
jgreening
Joined Jan 17, '04
From Illinois
There is a picture somewhere that Coomer posted with a white car with 8" rims and a 35 offset that had an almost perfect flush look. Keeping in mind that 1" = 25.4 millimeters (one half of which is 13mm), the correct offset could be as low as 23 (at least for the rears).
See this link:
offset calculator
post Dec 3, 2004 - 5:22 PM
ahhh, i think i get it. the link coomer provided cleared it up a little.
so, offset is not the thickness of the rims mounting point......its how far away from the center if the rim with the mounting point is, right? and this is what makes them stick out more or less?
post Dec 3, 2004 - 5:31 PM
jgreening
Joined Jan 17, '04
From Illinois
correct. Its the distance, expressed in positive or negative numbers, from the center point of the rim if you were looking straight down on it as it sits on your car. A positive number means the mounting point is closer to the front of the rim than the center point. A negative number means the opposite.
post Dec 3, 2004 - 5:39 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I'm sure you can run high 20's offset. I'm running -9 offset wheels on my Corolla and it's all good (lowered and all). AE86 corollas run stock offset in the low 20's and teens...
post Dec 3, 2004 - 6:17 PM
QUOTE(jgreening @ Dec 3, 2004 - 2:13 PM)
See this link:
offset calculator
[right][snapback]216439[/snapback][/right]
post Dec 3, 2004 - 6:40 PM
damn....thata 100% the look im going for!!!
post Dec 3, 2004 - 6:56 PM
ghostdog
From ny to philly
QUOTE(Coomer @ Dec 3, 2004 - 7:17 PM)
[right][snapback]216471[/snapback][/right]
what kind of wheels are those? they look like black racing pro n1's but they don't come in that size confused.gif
http://www.1010tires.com/wheel.asp?wheelbr...ro+N1+%2D+Black
post Dec 3, 2004 - 7:02 PM
Maybe 1010Tires doesn't carry all of the sizes available(because I know there is a 18x9" version as well.) wink.gif
Lo-Fi Version Time is now: February 18th, 2025 - 3:52 AM
