any way to make 17x7s look flush, without using spacers |
Dec 3, 2004 - 7:14 PM |
so now that we got the size figured out. whats the cheapest place to get some nice 17x8s 35offset wheels. im looking to spend under 1,000 with tires...but so far that seems to be an impossible price for 8in wide wheels.
Dec 3, 2004 - 7:20 PM |
I'm not sure on that one Lagos. I think most of the cheap wheel/tire packages typically have 38-42 offsets to appeal to the masses(Honda.) I think Rota might offer a wide variety of offsets and widths on their wheels. Other than that though, the only other companies that I can think of with wide varieties of offsets and widths are expensive wheels...Volk, Advan, BBS, Work, etc.
Dec 3, 2004 - 7:21 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
QUOTE(lagos @ Dec 3, 2004 - 8:14 PM) so now that we got the size figured out. whats the cheapest place to get some nice 17x8s 35offset wheels. im looking to spend under 1,000 with tires...but so far that seems to be an impossible price for 8in wide wheels. [right][snapback]216503[/snapback][/right] yeah I don't think thats going to happen. your looking at 1200 at the very least 5zigen is probably the cheapest brand with those width/offset options |
Dec 4, 2004 - 7:54 AM |
strange thing is that 18x8s seem to be cheaper then 17x8s
Dec 5, 2004 - 12:05 PM |
here is another question. say i got with 17x8 35offset. what would be the widest tire i can get away with, without having and rubbing issues?
id like to do at least 225-45 or 235-45. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Dec 5, 2004 - 12:08 PM |
Enthusiast Joined Aug 22, '04 From kitchener,Ontario Currently Offline Reputation: 0 (0%) |
I think that the 225 35 is good but still pushing it thats as far as I would but its safe.
Dec 5, 2004 - 1:44 PM |
QUOTE(lagos @ Dec 5, 2004 - 5:05 PM) here is another question. say i got with 17x8 35offset. what would be the widest tire i can get away with, without having and rubbing issues? id like to do at least 225-45 or 235-45. [right][snapback]217099[/snapback][/right] I think those are a bit too big... I would go with a 40 series tire... but a 225/35 will be closer to the correct diameter. -------------------- "It's ok to be naked girl... I'm an artist!"
Dec 5, 2004 - 1:56 PM |
Enthusiast Joined Nov 14, '04 From Florida Currently Offline Reputation: 0 (0%) |
Hey Lagos
I have been trying to go for that look ever since I got my celica back in 99. I finally bought some rims that might make it work. waiting till friday for them to arrive. They are 18x8 with a 37 offset. I have looked everywhere for an offset lower than 35 but no one makes it. and the people that do make it are I think two pice (expensive) wheels. To get the flushed look I got all 18x8 37offset and then I'm gona add spacers in the back. my other option was spending $2500 for staggered offset wheels with no possiblities of rotating my wheels. I will post pics once I get the wheels on. Later, Lalith |
Dec 6, 2004 - 1:06 AM |
QUOTE here is another question. say i got with 17x8 35offset. what would be the widest tire i can get away with, without having and rubbing issues? id like to do at least 225-45 or 235-45. Unfortunately, there are not a lot of good choices of tires in 225 or 245 for our size wheels (tire and rim together). Its much more important to keep the overall tire and wheel diameter as close to stock as possible for gearing issues. However, its the rim width and not the tire width that makes a tire look wider. Tires expand to fill out the rim. The good news is that most tires in the 215-225 range will fit 8" rims without a problem. Your current tires will probably work if you still have good tread left. If it were me, I would go with 215/40 or 215/45. Check the rim width range on the tires. In 215, most will accomodate an 8" tire (some up to 9") with a measured rim width (ideal) of 7-7.5". If you want to see the rim width range or measured rim width of a specfic tire, you can just click on "specs" when you are viewing a specific tire on the tirerack website. Hope it helps. - Jay. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Dec 7, 2004 - 5:10 PM |
Enthusiast Joined May 19, '03 From NJ Currently Offline Reputation: 0 (0%) |
I have 17x8 rims with 215/45/17 rubber . Tires don't look proportional to rim width at all they looked so stretched as size 6 sock on size 13 foot. I would say go at least 225. I just got myself a set of Michelin Pilot sport A/S 235/45/17. As well 215 will not give you any side protection to avoid from scratching rims. I'll post pic as soon as I put them on.
Dec 7, 2004 - 10:08 PM |
coom, do you have pics of that front with the 35 offset?
curious if it rubs -------------------- |
Dec 7, 2004 - 11:06 PM |
QUOTE I just got myself a set of Michelin Pilot sport A/S 235/45/17 I would like to see pics of those and know how it handles. They will make your overall wheel (tire and rim) diameter over 3 1/2" bigger than stock. Thats huge. Also, when you are travelling 70 mph, your speedometer will read 60. And, your gearing will be way off. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Dec 7, 2004 - 11:18 PM |
I found one tire that comes in a 225/35/17 which would be about perfect. Its pricey though:
Falken GR Beta FK-451 -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Dec 8, 2004 - 5:13 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
i have 17x7.5 and 35 offset, and with the 225x45 R17 im rubbing my tires in the back... front is ok...
-------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Dec 11, 2004 - 4:47 PM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
,,,And pay special attention to the part about:
"If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle." this is why you might want a wider wheel so the tire centerline stays as close to stock as possible as opposed to just getting a 7" wheel with a different offset. but, who knows, it may handle fine...also be aware it can put more stress on the wheel bearings and suspension parts when you radically change offset. you aren't talking about all that much change, just dont get crazy with it. |
Dec 11, 2004 - 8:12 PM |
235/45/17 is too big. It fits on the front only. So I have to drive for a week with 235/45/17 in the front and 215/45/17 on the back. Now I just have to order diff size. What you think 225/45/17 or 225/40/17
Dec 11, 2004 - 9:14 PM |
Can someone post a link to size,width and profile selection 'couse I just can't find it.
Dec 12, 2004 - 3:23 PM |
225/45/17 will work. There are a few people on here with that size. Mina comes to mind. However, they are bigger than stock.
Dec 14, 2004 - 11:23 PM |
TTE... does the rear just rub with the 235s? i talked to some people that said they trimed the inside of the wheel well to make wider wheels/tires work.
Lo-Fi Version | Time is now: November 25th, 2024 - 7:29 PM |
