Fiberglass or urethane???, Which would be better? |
Mar 21, 2003 - 1:37 AM |
Enthusiast Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
I've read that urethane is very durable, but that it's difficult to paint and is also prone to warping if it's heated or left in the sun for too long (not sure if this is true). But on the other hand, I don't want fiberglass which would chip very easily. What should I do?!?
Mar 21, 2003 - 1:51 AM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
quite honestly I don't know where you would get a urethane kit from, unless you import from Japan. but, if given the choice I would probably choose urethane because I occasionally have to drive in some pretty bad conditions. to each his own though.
Mar 21, 2003 - 4:46 PM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
you dont really have a choice, to get a urethane kit is going to be over 3K, fiberglass is pretty durable stuff as well, and is real easy to fix if it does break.
This post has been edited by K2_Celica: Mar 21, 2003 - 4:50 PM -------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 21, 2003 - 4:54 PM |
Enthusiast Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
I heard fiberglass isn't all that bad. What is the Zephyr kit made out of? What part of NJ are you from again? |
Mar 21, 2003 - 7:12 PM |
Enthusiast Joined Oct 9, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
out of curiousity what is our stock bumpers made out of?
Mar 21, 2003 - 8:33 PM |
Zephyr kit is made of fiberglass, as are all the other commonly available 6G kits in the US. and to answer your second question, I'm in central NJ. however I go to school in northwest NY which means I see a lot of inclement weather over the course of the year. |
Mar 21, 2003 - 11:27 PM |
a plastic urethane compound -------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 22, 2003 - 1:41 AM |
Enthusiast Joined Jan 30, '03 From Virginia Currently Offline Reputation: 0 (0%) |
I was under the impression that poly-urethane would be way better than fiberglass.
Mar 22, 2003 - 4:09 AM |
Enthusiast Joined Nov 13, '02 From Hawaii Currently Offline Reputation: 0 (0%) |
I say get the urethane and make a copy of it with fiberglass. So that way....you have both.
Lo-Fi Version | Time is now: November 25th, 2024 - 3:40 PM |
