> ITB + Turbo?, Is it possible?
post Dec 5, 2004 - 5:45 PM
Anub1s
Joined Nov 27, '03
Do you guys think that it is possible to custom weld an aluminum pipe to run from a turbo into the ITB's? Sort of like a reverse header where the pipes split and run into the ITB's. I can see where there would be a bit of an issue with too much boost running into one cylinder but do you think it would be possible?
post Dec 5, 2004 - 5:57 PM
shid
Joined Jan 8, '04
From LA
sure u could do that- but would it work? dunno
Kwanza26
Joined Dec 27, '03
From Nor Cal
It's possible and has been done. Take the 4AG 20V for example... they come with a factory box that bolts over the ITBs... All that needs to be done is to make a box where the compressed charge can flow into each throttle body... Tuning is killer with set-ups like this... but engine response in almost unmatched...
post Dec 5, 2004 - 6:03 PM
Anub1s
Joined Nov 27, '03
That is awesome thanks kwanza!
post Dec 5, 2004 - 8:04 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
lol, we have two identical posts within 5 of eachother
post Jun 14, 2005 - 10:54 PM
FallenHero
Joined Dec 26, '02
From Alabama
had a random ITB question and didn't want to start a new thread.
What are the port sizes on the 4ag small port? also, would the performance gains be significantly different if one use say... 38mm itb's instead of 41mm itb's? All other things being equal that is.
Lo-Fi Version Time is now: December 1st, 2024 - 6:04 AM
