> shifter
post Dec 8, 2004 - 3:07 PM
eclipse_04a
Joined Aug 22, '04
From Menomonie, WI
how do i remove the shift knob and boot from the stick and the plastic trim?
post Dec 8, 2004 - 3:48 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
You should just be able to twist off the shifter knob, and loosen up the shifter boot and pull it off. I don't know how to take off the plastic part that the boot is sew into. I would just imagine to cut it or make your own.
This post has been edited by C3L1CA: Dec 8, 2004 - 3:49 PM
-Brad
01 a4: daily
post Dec 8, 2004 - 3:49 PM
juBz86
Joined Aug 18, '04
From NJ
QUOTE(eclipse_04a @ Dec 8, 2004 - 8:07 PM)
[right][snapback]218689[/snapback][/right]
the shift know simply twists off(it may take some effort but it eventually twists off). the boot is connected to the plastic rim which pops off pretty easyily if you pry it out i usually use my hands(dont be afraid to give it a good tug).
post Dec 13, 2004 - 12:09 AM
importceli
Joined Jun 26, '04
From Bay Area, California
yea i kno i pulled my shift knob off just from curiosity, it started twisting so i just well, kept twisting it and it came off then naturally i took apart the rest of it, the shift boot and the center consol.
Lo-Fi Version Time is now: November 28th, 2024 - 9:06 PM
