SWAY BARS, Suspension techniques |
Oct 8, 2010 - 10:43 PM |
Enthusiast Joined Mar 3, '08 From New Zealand Currently Offline Reputation: 1 (100%) |
^you have whiteline front and rear??
-------------------- _______________May COTM 2011_______________ |
Oct 9, 2010 - 4:43 AM |
I'm Comparing the C-One Sway bar used on Superstrut Suspension vs the Suspension Technique used on McPherson Suspension. Two total different suspensions set ups
This post has been edited by BonzaiCelica: Nov 12, 2013 - 6:47 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 9, 2010 - 10:43 PM |
Im about to lose it. Freagin have some loose part or something lose in the engine that is loose when I give it gas really fast on and off in 3rd gear when I'm at 2,000 rpm. I tightened motor mounts to 64 ft lb tq. But it still makes the same noise. The thing that pisses me off so bad is the stupid front sway bar. How the hell are you supposed to take off the bolts that hold it down. You only have such limited space with the allen wrench wtf!!!! Im going and try to tackle it tomorrow but can someone help me or give me some tips in how to make my life much easier with those damn screws!!!
Yes I have the ST sway bars with the polyurethane bushings. I believe they need some grease which could be causing the clunking noise! help!!?? -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 10, 2010 - 3:47 PM |
pointless information. updated on 11-12-2013
This post has been edited by BonzaiCelica: Nov 12, 2013 - 6:48 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 11, 2010 - 5:27 PM |
Enthusiast Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
Im curious whats the best sway bars to get, idk if anyone can point me in the right direction. it seems like there has been issues with previous designs and now it has improved? maybe i read it wrong, there was alot of post about loud noises. i dont want that lol.. does the new ones still make noise?
im looking for front and rear sway bars. i want to up grade my suspension after i finish my swap. so fair i just lowered it on kyb struts and sportline springs. -------------------- st205 powered ss3 coupe
Oct 11, 2010 - 6:51 PM |
Im curious whats the best sway bars to get, idk if anyone can point me in the right direction. it seems like there has been issues with previous designs and now it has improved? maybe i read it wrong, there was alot of post about loud noises. i dont want that lol.. does the new ones still make noise? im looking for front and rear sway bars. i want to up grade my suspension after i finish my swap. so fair i just lowered it on kyb struts and sportline springs. wow dude it clearly states that the old version Suspension Tecnique sway bars use to hit the frame. The new ones don't. Your only option is Suspension Technique sway bars front and rear should cost you around $300 ish plus shipping. They come powder coated lime green so that you know they are the 2nd version. they work great get them!!! -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 11, 2010 - 7:33 PM |
Im curious whats the best sway bars to get, idk if anyone can point me in the right direction. it seems like there has been issues with previous designs and now it has improved? maybe i read it wrong, there was alot of post about loud noises. i dont want that lol.. does the new ones still make noise? im looking for front and rear sway bars. i want to up grade my suspension after i finish my swap. so fair i just lowered it on kyb struts and sportline springs. wow dude it clearly states that the old version Suspension Tecnique sway bars use to hit the frame. The new ones don't. Your only option is Suspension Technique sway bars front and rear should cost you around $300 ish plus shipping. They come powder coated lime green so that you know they are the 2nd version. they work great get them!!! yaa.. i seen that it said the old ones hit and then somethin about newer version was better along the way but i still seen some posts about noises. so i was just asking dude. they seem pretty easy to install. do u recommend doing the poly bushings too? and how did u make out with the front sway bar? get it in yet? This post has been edited by Ted95: Oct 11, 2010 - 7:35 PM -------------------- st205 powered ss3 coupe
Oct 11, 2010 - 9:05 PM |
Enthusiast Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
ask dustin and steff how much they like their poly bushings do it dude and the endlinks
Oct 11, 2010 - 10:09 PM |
ask dustin and steff how much they like their poly bushings do it dude and the endlinks ya ill prob ask them about it next time i see them, hopefully it will b when im swapping the sway bars is going to b my winter project .. im just gunna get the car swapped and running (also learning how to drive it) then put the sway bars and have it ready to rock for the srping lol -------------------- st205 powered ss3 coupe
Oct 11, 2010 - 10:15 PM |
Enthusiast Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
oo also for the front Super Strut Set up. Which end links can I use: -Two R Us ST185 end links ??? or -Racing Beat Miata end Links??? Oh wow, wait a sec, the TwosRus 185 endlinks work with the st202/205 Superstrut? -------------------- (\__/)
Oct 11, 2010 - 11:57 PM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
I doubt any of those would fit, since they are USA shops (and USA didn't get 6th gen superstrut)
best bet would be to check UK/europe aust NZ and Japanese sites for those parts. Fensports do some for the SS ST205 and ST202 (not too sure what suspension set up -------------------- |
Oct 12, 2010 - 12:12 PM |
what end links do we use for the rear ST sway bars? i have KYB struts .. idk much about the suspension deal lol
Oct 12, 2010 - 9:12 PM |
use racing beat miata end links 90 i believe
Oct 13, 2010 - 11:06 AM |
use racing beat miata end links 90 i believe ok cool, thanks johnny ill look into them -------------------- st205 powered ss3 coupe
Oct 13, 2010 - 3:08 PM |
dustin has them also lol !
Oct 13, 2010 - 5:18 PM |
dustin has them also lol ! ya i looked thru D's profile but it doesnt say he upgraded his sway bars.. so idk if it would work on the aftermarket sway bars u kno? -------------------- st205 powered ss3 coupe
Oct 13, 2010 - 9:21 PM |
yeah they work culp has them on his celi
Oct 29, 2010 - 11:25 PM |
as to how the hell this even happened I have no clue! pot hole doubt it driving so much in the canyons that it suddenly decided to break off??!
also the left side a arm is about 40,000 miles old and the car has 130,000 miles on it. The insurance company replaced it when my bro crashed this car by going up a curb and into some bushes, which was then handed over to me but this is so weird! welding is a quick fix, but if its weldable when I ask around and snaps again. I'll need a used one!!! This post has been edited by BonzaiCelica: Feb 25, 2013 - 4:30 AM -------------------- Group buy to replicate Narrow E series transaxle parts
Oct 30, 2010 - 5:49 AM |
Enthusiast Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
I've heard of this happening on the rear but not the front, I guess the sway bar was so stiff it snapped it, can see how it happened...and no wonder it was clunking haha, my rear came slightly loose and made lots of noise.
Oct 30, 2010 - 1:25 PM |
I've heard of this happening on the rear but not the front, I guess the sway bar was so stiff it snapped it, can see how it happened...and no wonder it was clunking haha, my rear came slightly loose and made lots of noise. yes hopefully i can get a quick fix that will last me another 8,000 miles. I planned on going to the canyons but now I have to fix this. I need to loosen the polyurethane bushings so I can lube them up and move the sway bar. Hopefully I didn't twist the sway bar. I hate greasing up the front sway bars such a pain in the ass!!! -------------------- Group buy to replicate Narrow E series transaxle parts
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:42 PM |
