Fitting Question |
Fitting Question |
Dec 8, 2004 - 7:09 PM |
Enthusiast Joined Sep 23, '03 From Miami,FL Currently Offline Reputation: 0 (0%) |
hey guys havent posted in a bit because i have been saving money and finally its time to give the lady a present...Question: If i get the stock gt4 front bumper w/o the hood meaning i will be putting the front bumper with my stock hood will there be a gap? or the gap only shows if its the gt4 hood with stock front?
thanx |
Dec 8, 2004 - 10:50 PM |
:bump:
Dec 8, 2004 - 11:09 PM |
Enthusiast Joined Aug 22, '04 From kitchener,Ontario Currently Offline Reputation: 0 (0%) |
I think that there will be a bump.
Dec 9, 2004 - 1:15 AM |
well with a gt-4 front bumper and stock hood you'll have a gap but facing the windshield meaning if your in the car you can see into the bumper
Dec 9, 2004 - 2:58 PM |
as figured thank you
Dec 9, 2004 - 3:02 PM |
one more question...is ALL the stuff on this list Needed to fit the Front bumper?
GT-Four Hood and Bumper - This is the hood and front bumper combination that can be found on all sixth generation Celica GT-4s. It's highly recommended that you buy both at the same time, because if you only buy one without the other, there will be a ugly, noticable gap in the center of the car where the hood meets the front bumper. The part numbers for everything necessary are below. Bumper Parts Cover, front bumper 52521-20200 $223.27 This is the bumper Absorber, front bumper energy 52611-20150 $62.76 This is the foam that goes behind the bumper Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Grill, sub-assy, rad., center 53101-20500 $46.29 This is the upper grille Grill, radiator, lower 53111-20750 $125.08 This is the lower grille Bezel, grille, lower RH 53112-20240 This is the right-hand bezel for the lower grill without fogs Bezel, grille lower LH 53113-20180 This is the left-hand bezel for lower grill without fogs Front turn signal, RH 81510-20750 Front turn signal, LH 81520-20750 Fog Lights and other Optional Parts Fog lamp, RH 81210-20370 Fog lamp, LH 81220-20360 Bezel, grill lower RH 53112-20230 This is the right-hand fog light bezel Bezel, grill lower LH 53113-20180 This is the left-hand fog light bezel Latch, hood, LHD 53510-20510 This is the left-hand-drive GT-Four hood latch, without it, you'll have to lengthen your stock latch by about 1/2 inch. Bracket, upper grill #1 53115-20070 $13.95 This is 1 of 2 brackets which hold in the upper grill Bracket, upper grill #2 53118-20070 $15.46 This is the 2nd bracket for the upper grill You can also get the reinforcment bar(your "crash-bar" or 5MPH bumper) and frame brackets, but theyre not nessicary, and the frame brackets required to use them are $180 EA from toyota. so just about everyone dont get it, they just cut down theyre crash bar with a sawzall. |
Dec 9, 2004 - 7:34 PM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
yup that looks about right.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Sep 16, 2006 - 4:41 PM |
Enthusiast Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
QUOTE(initialdrift55 @ Dec 9, 2004 - 3:02 PM) [snapback]219241[/snapback] one more question...is ALL the stuff on this list Needed to fit the Front bumper? GT-Four Hood and Bumper - This is the hood and front bumper combination that can be found on all sixth generation Celica GT-4s. It's highly recommended that you buy both at the same time, because if you only buy one without the other, there will be a ugly, noticable gap in the center of the car where the hood meets the front bumper. The part numbers for everything necessary are below. Bumper Parts Cover, front bumper 52521-20200 $223.27 This is the bumper Absorber, front bumper energy 52611-20150 $62.76 This is the foam that goes behind the bumper Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place Grill, sub-assy, rad., center 53101-20500 $46.29 This is the upper grille Grill, radiator, lower 53111-20750 $125.08 This is the lower grille Bezel, grille, lower RH 53112-20240 This is the right-hand bezel for the lower grill without fogs Bezel, grille lower LH 53113-20180 This is the left-hand bezel for lower grill without fogs Front turn signal, RH 81510-20750 Front turn signal, LH 81520-20750 Fog Lights and other Optional Parts Fog lamp, RH 81210-20370 Fog lamp, LH 81220-20360 Bezel, grill lower RH 53112-20230 This is the right-hand fog light bezel Bezel, grill lower LH 53113-20180 This is the left-hand fog light bezel Latch, hood, LHD 53510-20510 This is the left-hand-drive GT-Four hood latch, without it, you'll have to lengthen your stock latch by about 1/2 inch. Bracket, upper grill #1 53115-20070 $13.95 This is 1 of 2 brackets which hold in the upper grill Bracket, upper grill #2 53118-20070 $15.46 This is the 2nd bracket for the upper grill You can also get the reinforcment bar(your "crash-bar" or 5MPH bumper) and frame brackets, but theyre not nessicary, and the frame brackets required to use them are $180 EA from toyota. so just about everyone dont get it, they just cut down theyre crash bar with a sawzall. by any chance do you have the part number of the Reinforcment brackets plz -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 11:54 AM |
