Enthusiast ![]() ![]() Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) ![]() |
Engine Restorer
Review Anway figured I'd give it a shot since the 7A (115,000 mi) is consuming about a quart every 1500 miles. The stuff is purple, give you guys an update if the oil consumptions is reduced. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) ![]() |
A friend of mine bought a big kit with oil, radiator, and maybe tranny fuild restor thing. I can't remember how much he said it was, but he did say it worked great. He put it in a little 80something dodge pickup. If your going to do it, go all the way and get all the stuff. As far as though oil restore things, most are usually just thinkiner. I sugest finding the leak and fixing it. I don't care how much money you have, or don't have, fixing that leak should be the first thing you do.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
Yeah my engine burns oil after 2000k every oil change, so every time i just use like risonline.. which really just thickens it.. but it helps alot, and is only an extra 3 bucks per oil change.
i used it great stuff!!
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) ![]() |
i think i'm going to try it out, the review was ok, i'll look around of course. I would like to know what Kwanza has to say about it. But, every morning that i have to do a stone-cold startup, a little puff of blue, and that's all i see untill i have another stone-cold start.
-------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Thats water in your engine. That's bad.
Enthusiast ![]() ![]() Joined Aug 19, '04 From Berkeley Currently Offline Reputation: 0 (0%) ![]() |
hmm. I thought that puff of blue smoke was old/leaking valve seals - a common problem that really isn't very harmful. ..
I've got it as well.. |
i must admit, i've never heard such a thing as "water in your engine" creating blue smoke. Thought it was just the valve seals or scratches in the cyl. walls causing the oil leak
stupid flood control thing
This post has been edited by spunky393: Dec 9, 2004 - 10:25 PM -------------------- ![]() The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Well, that's what I've heard. I can't remember were. It's one of those things that you hear and then always assume it's right. I've never really even thought about it. Probably not true. I guess that's way you shouldn't take one person's word on anything. Either way, the leak needs to be fixed.
Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) ![]() |
Actually, little bit of water in your combustion chamber cleans up the carbon buildup as it burns off... And.. Yeah.. Or something..
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) ![]() |
oil additives are pretty helpful actually. my friend uses it on his 165k miles 3000gt and i use to use it on my hyundai accent awhile back. my old car use to burn oil like crazy and oil additives helped alot. dont try that fuel system cleaner tho, the grime will just wash up then build up on 1 particular spot, ur cat converter. well i think thats what my mechanic said
![]() -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
I just picked up a couple of cans at the Dollar Store
Two cans?
why not ? at a buck each you can't go wrong
Lo-Fi Version | Time is now: February 23rd, 2025 - 2:09 AM |
