3g 3sgte into a st, wiring help |
Dec 9, 2004 - 9:07 PM |
Enthusiast Joined Jun 27, '04 From ohio Currently Offline Reputation: 7 (100%) |
I know this question has been asked alot. I have a couple of good posts saved. Does anyone have personal experience with wiring an st205 engine into an st? I know wiries need to be lengthed and the fuse box plug etc etc. I am going to need some help. I have a 7a wiring diagrams and st205 wiring diagrams. Is it pretty self explanning what pinouts need to be repined? What I don't really know is what needs to be dome to the 3 interior plugs above the ecu? Any help would be greatly appriciated. thanks lance
Dec 10, 2004 - 5:19 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
1st step, remove the wire looming and label every wire using your wiring diagrams. Once you do that, it will start to make a lot more sense.
-------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Dec 10, 2004 - 8:26 AM |
You dont have to lengthen the harness if you tap another hole in the firewall. I did this because the less cutting and soldering the less likely to have a voltage problem.
Lo-Fi Version | Time is now: November 28th, 2024 - 6:32 AM |
